1200 rear end
are they wearing?
1. yes
1
17%
2. maybe
1
17%
3. no
3
50%
4. do splines wear out?
1
17%
Total votes: 6
1200 rear end
I have noticed the splines on the rear of our 1200 are showing wear and so was searching fleabay. . So looking for some "expert" eyes.
On this one, it appears the splines may be wearing, but what do you see?
http://www.ebay.com/itm/Honda-Goldwing- ... 1b&vxp=mtr
Sagebrush
Re: 1200 rear end
Post by Sagebrush »
From what I can tell I don't think I see much wear in those splines on either the drive or the hub. I've seen some splines from some 1100s that I parted were worn to needle points. Make sure you slather on a good dollop of moly lube on the splines during every rear tire change. I've had friends who owned Valkyries and wore the rear splines out until they started applying moly during tire changes which stopped the wear. I don't think it was a procedure in the service manual to lube the splines but it worked.
Graham Cracker
Re: 1200 rear end
Post by Graham Cracker »
Not much if any...unfortunately the seller doesn't reveal the mileage
Mark
1976 GL 1000 Sulfur Yellow
1977 GL 1000 Pearl White
wog
Re: 1200 rear end
Post by wog »
rcmatt007 wrote:snip...
Not an expert, but,
That is toast!
Maybe I'm off base, but this is how it should look...
I never want to see those chips in there.
On a side note, I'm still planning on making the Eastern Run.
I can bring this one up and you can take a look if you want to haul it home.
Forget what GL1200 it came from, but looks in great condition.
Your's for free, just for all your (and Redwood's) efforts to set up the run. anim-cheers1
82aspy
Re: 1200 rear end
Post by 82aspy »
rcmatt007 wrote:I have noticed the splines on the rear of our 1200 are showing wear
mileage?
ngw quotes anim-cheers1 - \ "I will strip the beast" \ "the swingarm is just a hunk of metal" \ "gonna maybe ...dunno yet" \ "It's never done, thats the fun." \ "something about this site brings me back"
Re: 1200 rear end
unfortunately mileage is not given. The ones on our 1200 are just slightly worn, but I wanted a backup. I always put moly on, but it doesn't help we also have a sidecar, which is a bit tougher on all components
