adjusting valves?
gungadin
adjusting valves?
Post by gungadin »
Is there a thread for proper valve adjustment procedure '75 GL?
'75GL "LIL WING"
If you aren't making mistakes you aren't doing anything.
GL1-242
Post by GL1-242 »
It is pretty clear in the manual.
You have one. If not I can copy the instructions down for you.
These valve's you do cold.
Paul
84 GL1200 STD
75 GL1000 #202
75 GL1000 (AKA, GL1-242)(AKA, Flipper)
76 LTD
76/77 CB750F
Bultaco's = 121, 152, 167, 188
Frenchy
Post by Frenchy »
I'm sure with a little coaching, our in house librarian can find a clear pictorial (complete with description) to post............ ;)
Frenchy
octane
Post by octane »
Frenchy wrote:I'm sure with a little coaching, our in house librarian can find a clear pictorial (complete with description) to post............ ;)
..who?
gungadin
Post by gungadin »
I found my Haynes manual in a box of parts down at my storage unit.
the following is plagerized from said manual.
If someone sees something wrong here SPEAK UP! I will edit
Adjusting the valve clearances. (Engine Cold)
Rotate the engine until both valves on No.1 cylinder are fully closed and the ‘T-1’ mark on the flywheel is aligned with the index marks. With the crankshaft in this position, number 1 piston is at TDC. Check the following valves by placing a 0.004â€ÂÂ
'75GL "LIL WING"
juniorloz1
Post by juniorloz1 »
Alot of riders skip this step. Valve lashing your motor is a vital maintenance procedure and should be taken seriously and accurately!!!!
My Girl, 1981 gl1100 Stripped Naked GOLDWING Interstate.
MY ALBUM, CHECK IT OUT DUDE:
http://www.nakedgoldwings.com/gallery/Juniorloz1
___________________________________
Loud Pipes Save Lives... JESUS Saves Souls!!!
Make HIM your co-pilot today.
-CHOP IT or DROP IT!!!
-If it ain't broke, MODIFY IT!
-Ride it like you stole it!
-When God's right, i'm right, when God's wrong, we don't fight!
Ride Safe>PEACE
Email: junior@lozzi.net
octane
Post by octane »
Alternatively
from The Honda Mothership:
Lars
About that second illustration, is that from the standard manual or one of your personal references? It is a very interesting illustration and one I do not recall seeing before?
Steve
octane
Post by octane »
Hi Steve
Yep
It's from the original 1975 Honda Workshop Manual that I have,
not the (later) reprint. (in which one will not find it).
octane wrote:Hi Steve
Ahhhh... No wonder I don't recall it :-D
Thank you Sir!
Frenchy
Post by Frenchy »
octane wrote:..who?
Why who else????
Frenchy
gungadin
Post by gungadin »
And done before a carb sync.
'75GL "LIL WING"
