Brakes; getting closer. Opinion on pads and more
- bonestock3
Looking at this set
To replace my current brakes Bought a torque wrench to get into the brakes. Noticed how the pads are crumbling apart; ordering now.
The discs don't feel bad but might replace while I'm at it. Might go slotted/drilled. Any recommendations?
Bonestock©
1979 GL1000 - Avomew
- BlueThunder
Re: Brakes; getting closer. Opinion on pads and more
Rather than Kevlar, I prefer the EBC semi-sintered pads. They were called "semi-metallic" back in the day. Better stoppage without sacrificing wear. Does not damage brake rotors as well.
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
- chewy999
My pads of choice are EBC, but sure others will have their own favourites.
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
- chewy999
Why did you buy a torque wrench to get into your brakes? Surely you would be loosening stuff off.bonestock3 wrote:
My (limited) understanding, is that you shouldn't use a torque wrench as a normal lever, just for what it says on the tin!
Previous Rides,
Current bikes
Current bikes
- bonestock3
I've been loyal EBC but at this price I had to ask.
I read a sticky on brake job and it was listed as a required tool; it'll come in handy eventually
Bonestock©
- Sagebrush
Can't go wrong buying a torque wrench, only use it to tighten bolts though. Never to loosen. I'm on the EBC bus as well.
- NCScooter
- My Album: http://ngwclub.com/gallery3/index.php/w ... ter?page=1
I had a pair of kevlar (ebc) on the back, did not last as long as I would have hoped. I would imagine they'd get ate up on the front.
I need to remember to keep my expectations tiny so I don't end up so whiny.
1976 CB400f
1977 GL1000-The Breeze
I'm so special, my short bus only has two wheels!
1976 CB400f
- zman
For what its worth I have those pads, almost 4K on them and still look pretty thick, had them off the other day to install the new front tire, stops rapid enough but who's to say whats enough.
1980 1100 Interstate, 1978 GL1000
- bonestock3
Ha thanks! Only use to tighten not loosen - that's sound.
Bonestock©
bonestock3 wrote:Ha thanks! Only use to tighten not loosen - that's sound.
If it is the "clicker" type you should also set it to the lowest setting after you are finished using it. Don't put it back in the tool box with it still set to 80lbs-ft. (that's just a number I pulled from the air)
If it came in a case use it. Torque wrench's are fairly delicate and calibrated instruments. Some of the cost a lot of money. Take good care of it. Some say they should be recalibrated every few years.
- NCScooter
Not to stir up a hornet's nest, but it seems I read somewhere the bar/pointer thingy were more accurate. Is this true?
1976 CB400f
1976 CB400f
The beam type has always been given that reputation. I won't say either way. But you do need to be careful with the way you store those too. I have both a beam type and 3 "clicker" type. The beam can be a pain to use at times. You do have to be able to see it directly to read it. Not always easy when working on an assembled bike.NCScooter wrote:Not to stir up a hornet's nest, but it seems I read somewhere the bar/pointer thingy were more accurate. Is this true?
I have a couple of the clicker type. Have had them for many years, and have had them checked a couple of times. They have not lost calabration over time. But I do keep them in the cases, and at the lowest setting when not in use
- ianstaley
Brake pad choice is something very personal but which brake pad and why? I found this which makes for good reading and may influence your choice.
go here for the article make good quick reading. http://www.ebay.co.uk/gds/Which-Brake-P ... 378/g.html
Ian
Ian
- bonestock3
* thanks Was certainly an enlightening read, it seems Kevlar isn't the best option for every day use. Fondly appreciate ur sharing.ianstaley wrote:Brake pad choice is something very personal but which brake pad and why? I found this which makes for good reading and may influence your choice.
Ian
*it certainly is the clicker type. So store at lowest setting. Easy. Where would I take it to get recalibrated? What might cause them to lose calibration?robin1731 wrote:
I like keeping it in the case like some magic wand.
Bonestock©
- 168 Replies
- 15157 Views
Last post by Lucien Harpress
- 820 Views
Last post by dl1000
- 424 Views
Last post by salukispeed
- 11 Replies
- 444 Views
Last post by MegaDan
- 10 Replies
- 893 Views
Last post by Graham Cracker
