is the 84 stator unique?
- pugetsoundsailer
I'm getting mixed messages, got a ebay seller saying saying his stators will only fit 85 and up.
Then others saying the 85 stator will fit the 84, what gives???
Ride'on.............
78 Naked Custom GL-1000
84 GL-1200 Standard
88 VN-1500
98 XR-400
84 GL-1200 Standard
88 VN-1500
98 XR-400
- FLASH2002
Re: is the 84 stator unique?
Hi, the stators are all the same from what I know, 1000, 1100, 1200 are all the same.
'79 GL1000
'82 GL1100
'82 GL500
'84 GL1200
'03 GL1800
'82 GL1100
'82 GL500
'84 GL1200
'03 GL1800
Some 1200's had a larger stator, the 85, maybe just the LTD, but I think 85 and up were a bit different. They had a little more juice.
- Old Fogey
This is 'quote'-as far as I know:
The same stator will fit all 1000,1100 and non-injected 1200
That said, the original 1000/1100s were rated at 300 watts and the 1200s were rated at 350.
The injection models had a bigger stator and rotor and were rated at 500. They also have a bigger rear engine case to accommodate it.
one thing that is different is the pulsar hangs off the back end on the 84 and it is ties to the front shaft (and pully for the timing gears) 85-87. And yes the Ltd is different
- jdvorchak
I'm pretty sure all the 1200s, other than the FI LTD, had the same stator. 350 or 360 watts, don't remember for sure. I looked once for Ricks Electrics stator and it showed the same part number for 1000 1100 and 1200 as I remember.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
if that is so, then the still available OEM stator for the 1200 should fit into a 1000??
- pugetsoundsailer
if this is the case can the 85-87 be adapted to fit the 84?rcmatt007 wrote:one thing that is different is the pulsar hangs off the back end on the 84 and it is ties to the front shaft (and pully for the timing gears) 85-87. And yes the Ltd is different
84 GL-1200 Standard
88 VN-1500
98 XR-400
84 GL-1200 Standard
88 VN-1500
98 XR-400
- Old Fogey
The 84 was a one year only engine. The whole thing was comprehensively overhauled for the 85 on models.
Crankcase, rear case, clutch cover, etc. None of these interchangeable with the 84.
The front-of-crank ignition system pick-ups also have mounting points on the block, if I remember rightly.
So I guess the answer is no.
- jdvorchak
Old Fogey is right. No way to use 85+ pulse gens on the 84
2021 HD Triglide
John
2021 HD Triglide
John
- pugetsoundsailer
yes that is correct concerning the pulse generators, my question is can the stator of a 85 be used in a 84?jdvorchak wrote:Old Fogey is right. No way to use 85+ pulse gens on the 84
84 GL-1200 Standard
88 VN-1500
98 XR-400
84 GL-1200 Standard
88 VN-1500
98 XR-400
- John Schmidt
I have a stator out of an '84 I have no need of, pretty sure it's good. Have to check, pulled it out of an '84 engine from a Std.(swallowed a valve). Shoot me an email at stuffy402@aol.com if interested.
I think the general feeling is yes, but no one is for sure.pugetsoundsailer wrote:yes that is correct concerning the pulse generators, my question is can the stator of a 85 be used in a 84?jdvorchak wrote:Old Fogey is right. No way to use 85+ pulse gens on the 84
What I do know is that honda had problems with the stators failing in the 84's and most of them were replaced before the 80's were even over. It is possible that a different part # reflects the changes they made after those failures.
Sort of like the part # for the drive shaft changed during the 1000 series. The later ones had a better u-joint, but they all interchange
When I get back out to OK, I will check as I have a new stator to put into our 1200, and I can compare it to a used 100 stator I have on the shelf. The other option is that I have a used 78 engine that needs the rear case gasket replaced, and I can pull that and see if the 1200 stator actually fits
- 8 Replies
- 1158 Views
Last post by Whiskerfish
- 3 Replies
- 781 Views
Last post by Easter
- 9 Replies
- 904 Views
Last post by calif wingnut
