re- jetting
- Rdltmc3
re- jetting
So i have a slight backfire on the exhaust side, i also have some pretty free flowing mufflers (basically straight pipes)
should I be re-jetting the carbs to help out here?
also where is a good place to buy jets for our carbs and what would be a good size to increase too?
exhaust is the only mod.
1978 gl1000 for sale to fund new project
Re: re- jetting
As much fun as re-jetting is, I don't think it will help your problem. You might start by adjusting the air jets a little. If you feel its running to lean, decrease the air in the air/fuel ratio
Re: re- jetting
Popular thinking is that changes to the exhaust will have little effect on running issues. However a little back pressure is is required
Re: re- jetting
Jetting is different from bike to bike. You can start with one size bigger. But there is more than one jet in these carbs. Then air jets too not just fuel. Takes time and patience.
- Rdltmc3
Re: re- jetting
Air/fuel screw on carb #2 seems to do nothing, but the bike runs perfect so I haven't put much time into it.
Re: re- jetting
That might be the source of the backfire
- Rdltmc3
Re: re- jetting
slow idle jet correct? clogged usually or needs replacing?
If I was going to go in there and fix that what benefits or downfalls would i have by going up one size in the jets?
Re: re- jetting
Clogged more then likely. Or the passage is clogged
- gregforesi
Re: re- jetting
These bikes are a bit touchy on the intake side, but not very touchy at all on the exhaust side. I'm going to vote for a clogged idle jet.
The idle jets are .35mm or .013". Any little piece of crap that breaks loose somewhere can clog them. Since your #2 idle adjustment screw isn't doing anything, I'd pull the rack, drain it, flip it over, pull out the #2 idle jet, clean it out with a piece of wire the appropriate diameter (i.e. anything that will fit it without hurting it) and then throw it back together.
You can get drills from places like Production Tool Supply that will allow you to open up a jet to the size you like.
If you think a jet is too large, you can solder it closed and then use the correct size drill to open it up to a smaller size.
Generally speaking - a lean condition can cause backfiring through the intake. A rich condition can cause backfiring through the exhaust.
Benefits or downfalls from jetting...
It's about the mix for the particular motor. Too big and you waste fuel and maybe foul plugs. Too lean can be a very bad thing. Hard to start is a minor problem. Running lean can also cause high heat in the combustion chamber and that can burn a hole in a piston.
The bottom line is that no matter how you jet it, or how you tune it, mine will always be faster.
2006 GL1800 (Brutus Maximus)
- Rdltmc3
Re: re- jetting
Thanks, very inspiring.
- gregforesi
Re: re- jetting
Thank You. Always happy to provide inspiration so long as it doesn't interfere with that quote.
Re: re- jetting
If your idle mix screw is not doing anything that needs fixed. I went up a size on the main fuel on my 75 and probably could go another yet. I am running a oil type air filter and a 4 into 1 headers with no back pressure. The engine felt like it was running out of gas at Wide Open when approaching the red line and the plugs matched that feeling. Got my jets from Sirusconic I believe. Short of a before and after dyno run there is no real way to quantify the value of the effort.
Re: re- jetting
Rdltmc3 wrote:Air/fuel screw on carb #2 seems to do nothing, but the bike runs perfect so I haven't put much time into it.
Do the other 3 make a difference if you move them? If so then the number 2 carb is where you need to direct your attention. If nothing changes when you turn a mix screw in or out 2 or 3 turns that idle circuit is most likely plugged. When set properly 1/2 turn will/should make a difference. But that can be hard for some to notice. So try 2 or 3 turns. That should be big. If you turn a mix screw all the way in and the engine doesn't want to die that circuit is plugged.
- Rdltmc3
Re: re- jetting
If it runs perfect..... leave it alone.Rdltmc3 wrote:Air/fuel screw on carb #2 seems to do nothing, but the bike runs perfect so I haven't put much time into it.
Cliff )
- 3 Replies
- 765 Views
Last post by arie1
- 11 Replies
- 621 Views
Last post by rcmatt007
- 8 Replies
- 424 Views
Last post by cmyoch
- 21 Replies
- 8441 Views
Last post by gregforesi
- 22 Replies
- 1377 Views
Last post by redglbx
