I am taking apart a rear case from a gl1100. I am trying to take out the stator and the pulse advancer both seem to be stuck?
I have tried a impact driver on the three Phillips heads that hold the stator in place but none will budge I am assuming they are standard counter clockwise to screw out..correct??? Any suggestions beside using an impact driver...
Second, to remove the electronic ignition assemble I have the cover and outer piece off, removed the advancer's contact head and the plastic spacer then I tried to drive the shaft out toward the inside of cover using a wood block and hammer???? seemed to move a bit but now stuck and I hesitate to pound any harder.. I did squirt a little WD at the shaft from both sides..
So am I on the right track or should I be doing something else????
Taking a part a rear case questions before I break something
- RB
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her ((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
Re: Takign apart a rear case questions before I break someth
The 3 bolts on the stator are LH thread yes. They can be very tight and stubborn though. Try placing the case on a piece of wood, 2 x 4 works. That gives it a solid surface but it also has a little give.
Can't help on the ignition part, sorry.
- RB
Yep that's what it's on for both issues 2x4' holding the case up off the workbench may move to the floor for a stiffer surface as my workbench moves/vibrates with every strike.
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
RB wrote:Yep that's what it's on for both issues 2x4' holding the case up off the workbench may move to the floor for a stiffer surface as my workbench moves/vibrates with every strike.
yeah, I do mine on the floor. I have a nice rubber pad on the floor, then use the 2 x 4's too. Sometimes it still takes a pretty heavy hit. I have already used a 2lb sledge along with the hand impact driver on some very stubborn fasteners.
Even after you get those screws out the stator can be tough to remove. It has to come out pretty straight.
- RB
Re: Taking a part a rear case questions before I break somet
got them both..vise grips on the stator bolts and a littel more pounding on the advance shaft..!!
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
Stubborn little buggers aren't they?
- 326 Views
Last post by deathbypizza
- 26 Replies
- 1703 Views
Last post by pidjones
- 16 Replies
- 435 Views
Last post by 82aspy
- 6 Replies
- 347 Views
Last post by SnoBrdr
