Fiberglass Manifolds
Posted: Tue Jul 22, 2014 12:59 am
So, there seems to be two camps in the single carb manifold discussion:
Metal or PVC/ABS
Has anybody tried fiberglass? I have to admit, I got the idea from the old 917 Porsche race car, which has a really chunky fiberglass manifold sitting atop the engine.
If anybody is interested, I could probably be talked into fabricating one of these. The big advantage is the ease of fabrication. You could literally cut round/square tubing with a disposable saw and miter box, then set all the pieces with kitty hair or lay it up with epoxy and glass tape.
I guess where I'm drawing a blank is on the carb flange, but pre-made FRP sheets have a thickness tolerance of +/- 0.008" per inch, which should be acceptable if a gasket is used and maybe a little glass sheet sanding is done.
Any ideas?
I see appropriately sized tubing with a 265 degree Fahrenheit heat rating (abs melts at 221F), so the biggest question is what kind of heat the bonding materials can take.
Metal or PVC/ABS
Any ideas?
