GoldWing Seat Wiki Identification and Compatibility - 1975-1984
- 77Pinto
Re: GoldWing Seat Identification and Compatibility - 1975-19
Great info!
The only thing I have a question on is that from your photos the 75 - 76 (non-ltd) do not have the chrome trim around the back of the seat, so if they share the same pans as the later 1000s, do they have the holes to mount the trim?
I know that the 78-79 stainless trim parts are slightly longer than the 76 LTD and the 77s so the mount holes are not quite right (found this out this morning). I made the front ones work, but I need to drill two more holes to mount the rear one.
Bill
Bill
1976 GL1000 LTD (X2)
1976 GL1000 Sulfur
1977 GL1000
1976 GL1000 Sulfur
1977 GL1000
- MJSWingman
Another example of why this forum is so excellent.
Many thanks, Placerville.
Mike
1983 Standard- Undergoing An Enforced Diet Towards Nakedness!
- Placerville
Very good question and good observation.77Pinto wrote:Great info!
Bill
Does anyone out there have a (for sure) '75 or '76 (non LTD) bare pan they could eyeball? The question is: Did the '75 or '76 (non LTD) pan come with factory pre-drilled holes around the back? (They wouldn't be used for those years but, would later accommodate the rear trim of the LTD, the '77, '78 and '79).
Keep the questions coming. Many eyes on this will find these errors.
Calif Wingnut, I PM'd you about your comment above. I need some clearifiacation.
- Tin Member
So it is certain that a 1983 seat will definetly only fit a 1983 and not 80 - 82 ?
1980 GL1100 Hondaline bags.
Added to Shoptalk in the "Other References" Section
- Placerville
Thank you, Whisker.
And now moved to the How-To Forum.
- calif wingnut
75-77 pans are the same, while the 78-9 have a deeper/taller rear metal lip section per the pictures here, maybe other mods per foam shape/height on the sides but will fit all 1000's.
- 78-9 rear pan 2"
- IMG_3081.JPG (133.91 KiB) Viewed 968 times
- 75-76 rear seat foam 1"
- IMG_3082.JPG (145.24 KiB) Viewed 968 times
- 78-9 foam 2"
- IMG_3083.JPG (131.81 KiB) Viewed 968 times
- 75 foam vs 78 78 foam shape is close to ltd and 77.
- IMG_3072.JPG (111.93 KiB) Viewed 968 times
- 78-9 have a plastic bead around the bottom edges/sides in an attempt prevent the cover from rubbing through on bare metal like 75-6.
- IMG_3075.JPG (97.46 KiB) Viewed 968 times
- Placerville
Nice info and photos! Thanks, CW.
- calif wingnut
All 1100 seats fit all models. In 83, Honda moved the trunk mount rack Back and Up with a higher passenger back rest for more passenger comfort and thus, extended the length of the rear seat to fill the void as I recall but, it won't make any sense to the bean counters so I'm probably wrong saying this ?NEDan wrote:So it is certain that a 1983 seat will definitely only fit a 1983 and not 80 - 82 ?
The 82/83 grey/tan/red Aspencade seat covers turned sticky/stained shorty after purchase this I remember very well.
Last edited by calif wingnut on Thu Apr 17, 2014 9:47 pm, edited 2 times in total.
- calif wingnut
78 with new dense foam in rider seat for improved comfort ? :<)
- IMG_3112.JPG (123.07 KiB) Viewed 961 times
- IMG_3100.JPG (118.2 KiB) Viewed 961 times
- 77Pinto
Will the 83 seat contact the earlier 1100 trunk rack? I have a 83 seat and its about 34.5" long overall.calif wingnut wrote:
.....All 1100 seats fit all models. In 83, Honda moved the trunk mount rack Back and Up with a higher passenger back rest for more passenger comfort and thus, extended the length of the rear seat to fill the void as I recall ?......
Also, I installed an 'ebay' "1976LTD" aftermarket seat cover on a 78/79 pan/foam. Other than the mentioned differences in the mount holes and trim, it worked fine with no issues on the lower rear section. It is a little loose fitting in the front 'butt' area, the "Honda" is not centered (none of the factory ones I have had are, but not as far off as this one), the lower seam is not even, and the front beading angles a little rearward of where it should be on the front edges. Please note that I used 76LTD/77 stainless trim off a different donor seat as the trim on the 78/79 seat I had was shot. Some of my issues might be due to using the wrong seat assy. for the LTD/77 cover, but the trim donor 77 seat pan is rusted and seems too weak to use, and I did not want to use the factory LTD seat even though the cover is split in two areas.
For what I paid for both the 78/79 and the 76LTD/77 ripped seats, new seat cover, and new aftermarket strap holders, I'm into this seat for under $125., and it works for me. That said, if someone does this and expects it to look like a $1000. seat; they won't be happy (well, not if I did it anyway). Similar to: If you go to Macco and pay them $500. to paint your car and you are expecting a $300. paint job, you will be happy....
If anyone wants, I can post photos of the seat I recovered.
Bill
1976 GL1000 Sulfur
1977 GL1000
1976 GL1000 Sulfur
1977 GL1000
- calif wingnut
I'd like to see it 77pinto to compare notes. I remember comparing the side chrome trim stud from my ltd seat vs the 78 seat, with the stud/hole nearest strap mount being a 1" difference.
I have a plain 78 pan here to compare to the 75-76 foam.
Placerville. I had a nice chat with you the other day, thanks for your topic here ~:<)
- Stock seat on my 86A
- IMG_3113.JPG (108.57 KiB) Viewed 928 times
- 83 standard seat-all 80-83 standard seats were the same pattern/design.
- IMG_3122.JPG (108.78 KiB) Viewed 928 times
- 83 interstate-note higher trunk rack/passenger rails-taller backrest.
- IMG_3123.JPG (124.1 KiB) Viewed 928 times
- 1200 retail back in the day
- IMG_2825.JPG (151.18 KiB) Viewed 923 times
- calif wingnut
Perfect 1100 Aspencade seat.
- DSCF9655.JPG (112.21 KiB) Viewed 921 times
- DSCF9656.JPG (110.44 KiB) Viewed 921 times
- DSCF9657.JPG (104.37 KiB) Viewed 921 times
- Placerville
As did I. And, thanks to your input, this write-up just keeps getting better. Where were you when I started this thing?calif wingnut wrote:I'd like to see it 77pinto to compare notes. I remember comparing the side chrome trim stud from my ltd seat vs the 78 seat, with the stud/hole nearest strap mount being a 1" difference.
- 19 Replies
- 607 Views
Last post by Gowing
