TwinDCOE installation on GL1000, manifolds ready for welding
Geezer Kneivel
Brass Member
Brass Member
Post by Geezer Kneivel »
Here are some in process pics of the DCOE conversion on my GL1000.
Geezer Kneivel
Brass Member
Brass Member
Re: TwinDCOE installation on GL1000, manifolds ready for wel
View from above, plenty of room for an airbox. Stock airbox planned, fed from "alternative source(s)".
Looks promising!
KYWinger
Post by KYWinger »
Nice work! action1 If the carbs flow more than stock, do you have other mods in line to take advantage of that? :?:
-John-
FTCS (SS) USN Ret.
'83 Aspencade
GWRRA KY- 'G'
past in time tony
Post by past in time tony »
Nice work, cant wait to hear it run. action1
1984 GL1200 Hack & 1975 GL1000
gregforesi
Post by gregforesi »
Short, full-radius velocity stacks right at the cab openings. They can be inside the airbox, but webers really like radiused openings. We're talking maybe 2 horses directly attributable to the v-stacks.
This was for an in-line car engine but its the thought that counts.
2006 GL1800 (Brutus Maximus)
joedrum
Post by joedrum »
i like the set up ...more compact and user friendly ...neat ...looks like the best set up for werber ive ever seen ...just great if it works good ....
1979 1000
Geezer Kneivel
Brass Member
Brass Member
I have about a week's work getting the manifolds welded, final fitting, etc. Linkages will follow so it probably wont run for a bit. This set-up will go on my other GW, it is running already. Bike pictured is my cafe mule, otherwise known as The Chicken Hawk.
geezer kneivel
Don_Karlos
Zinc Member
Zinc Member
Post by Don_Karlos »
Hi,
your setup is looking as if it was the original Prototype of Honda. Are the measurements really a perfect fit distance wise to the original intake manifolds? Which base jetting will you use to start with? Please keep us informed about your progress and about the outcome.
Thanks
Karl
CBX 1000 CB1 red
CBX 1000 CB1 black
GL 1000 Ltd
GL 1000 K3
BMW R100S
Z1300
HD Streetbob 2009
Simson S51N
Geezer Kneivel
Brass Member
Brass Member
I had to do some serious fettling to get the pair of stock intake runner elbows to align with the bore spacing of the Webers. They have been toed in, and the new carb flanges bored at a matching angle to make up for the nearly 200 thou difference. They are now a near perfect match and will blend nicely once some internal smoothing is done.
Still waiting for welding, but I have a slew of other projects on the boil while this is waiting to happen.
Carb jetting is a wait and see as well, but I have a box'o'parts on the shelf.........
Carbs will breathe thru a common airbox, and there is space for Weber velocity stacks in there. I expect the original but modified air box might feed the pair, expect to see two screened air inlets on the forward surface of the shelter sides, feeding fiberglass ductwork leading to the filter box. Sides will still open for access to sundry electrical and cooling components.
Gas tank might see an externally accessed fuel filler in the shelter center panel, fixed to the shelter frame so the panel will still open with a key. Maybe...........
Geezer Kneivel
Cheyenne, Wyoming
joedrum
Post by joedrum »
hmmmmm cool cant wait to see more
1979 1000
evilratwing
My Album: http://www.photobucket.com/evil03ratwing
Post by evilratwing »
I'm waiting on this as well! Very interesting stuff!!!!
The bike is essentially just another bike... The pilot is CRAZY.
Whargoul - Murdered out 1978 GL1000 - Engine KaBOOM.
Cherry Cough Syrup - 2009 Suzuki M90 - 3,300 miles.
Geezer Kneivel
Brass Member
Brass Member
Project is stalled for a couple more weeks, just finishing my Retro Direct RoadMaster bicycle, AND preparing for vintage racing driver's school (1275 MG Midget) to be held this weekend in Colorado. Pretty busy for an olde guy...........
Geezer Kneivel
I still cant believe how close those intakes come to matching up.
Geezer Kneivel
Brass Member
Brass Member
Sunn Bobb,
I opened the elbow base holes up a little to allow them to rotate a couple degrees while using stock hardware and o rings, then designed the alloy connector lengths so they met at the right distance apart when exiting the alloy flanges. Flanges are bored at that angle. It took some tricky fixturing but nothing much beyond my rudimentary skill set.
Anyone wanting more detailed pics, I'll take some when welding/brazing the parts together.
I was pretty sure this would work before cutting chips, but popular opinion said it would be difficult to pull off. That's all the encouragement I needed :)
GK
