How to replicate a simple emblem
Making A replica emblem
This is one of those tips that probably no else will need, but hey, if they do, here is how to do it.
Ingredients:
1. Emblem to be replicated
2. “Sculpty” modeling clay.
3. Silicon shoe spray (used for mold release)
4. Polyester casting resin and catalyst
Go for it
Take a handful of Sculpty and roll it around in your hands until it is soft and pliable.
Roll the Sculpty onto a flat surface, and flatten it with something like a plate.
Spray your original emblem with silicon spray and press it into the Sculpty using the flat plate again. Remove the emblem from the sculpty and place it in a preheated 200 degree oven for 15 minutes.
Remove the Sculty (now hard) and allow it to cool.
You now have a mold to use for casting. Spray the mold with the silicon and allow it to dry overnight. Spray it again and allow it to dry. Spray the silicon one last time.
Mix your resin ½ once of resin to 11 drops of catalyst.
Pour the resin into the mold, using a flat object to level and clean the excess off of the surface. I used a match book cover.
Allow the resin to harden (typically about 2 hours), and remove the cast using an exacto knife.
Allow the resin to set up for a couple of hours, paint it any color you want and apply!
Sagebrush
Re: How to replicate a simple emblem
Post by Sagebrush »
Pretty slick. tumb2
Bert
Post by Bert »
Very cool information...thanks for the write up.
"Try to be the person your dog THINKS YOU ARE"
'75 Red Wing Now Greene and Tan
'76 Yellow Wing...Sold
'77 Blue Wing
'77 Red/black wing with side car...Sold
'79 Silver/black CBX...Sold
'81 CB1100RB Red and white...Sold
'06 Ducati MTS 1000DS...SOLD
'01 CBR1100XX Redbird
Very cool.
Now if we could just replicate that dang gold on the GW emblems. :IDTS:
SloMo228
Post by SloMo228 »
Cool! Nice tip.
Steve
1978 GL1000 - Gallery
1993 GL1500 SE - frame-up restoration in progress
1983 CX650C
ianstaley
Post by ianstaley »
Wow that is such a great idea. I have a problem with the all the badges on the bike as someone already said how to replicate the Gold. What I have noticed is that the emblems are first painted or cast in black glossy finish, Honda then have it gold plated with some sort of paint. Same with the red parts on the emblems. Now it can be done. I bought a set of HONDA tank name plates from a place in Australia, so I know that it can be done, I have had a bit of a think about this so my idea is to remove the gold paint by vapour blasting which should be very gentle and not damage the badge.
Then using a quality black two pack paint respray the whole thing black. When dry to get the gold effect why not use gold flake. It isn't a huge cost. and when attached to the raised letter wings whatever would be very smooth. The just coat in a two K hard varnish 2 or three coats should be enough to protect the gold and the black.
For inside the raised letter and wing details you could use a red enamel paint that has a good holding properties and do the same finish with 2x top coat.
looking forward to seeing how that works
Me too, I've never done gold leaf.
Roady wrote:Me too, I've never done gold leaf.
I've never done it. But I know the process. It looks fairly easy.
