I wonder if you could please 'Cast your eyes over this for me and tell me what you think ? The dual IDF Webers mounted on either sides pair of cylinders look superb and undoubtedly perform very well....But as we all know they are expensive, VERY expensive!!!
The other GoldWing carb conversions that I have seen on the forum involve a variety of centrally mounted single carbs, which often seem to come with long inlet manifolds causing fuel puddling and poor running. ( No criticism is intended there, the single central carb just have their own unique set of problems that have to be overcome)
The original carburation was 2 x32mm or 2 x31mm or even down to 2x30mm per side so ....my question is, has anyone thought of fitting TWO Double barrel 'PROGRESSIVE' carbs ( of differing sizes ) per side and so per pair of cylinders. A Weber 28/36 would probably work fine because the total size of the carb when open is 64mm and the Wing is 64mm or 62mm ( or 60 mm ) per pair of cylinders.
The price difference between the carbs is amazing..the 28/36 Weber is so much cheaper ! so you save money! , you still get the 'Twin Carb Look' and the bike should perform at least as good as standard due to the double barrel Webers. and of course of having a shorter inlet manifold
All you would need is a pair of inlet manifolds...does anyone have any idea where a couple can be got cheaply
Your thoughts please gentlemen ?
Alb.
