FUEL FILTER GL1100
FUEL FILTER GL1100
CAN ANYONE GIVE ME SOME HINTS ABOUT CHANGING OUT MY FUEL FILTER? THERE REALY ISNT ANY ROOM DOWN THERE TO GET TO IT...AND I AM BURNING WAY TO MUCH GAS!!! THANX FOR THE HELP...MATT
- QUEEENlE
Don't know if this will help or not .... its all i got.
Hugs
Q
- octane
Re: FUEL FILTER GL1100
Hi MattMATTS WING THING wrote:CAN ANYONE GIVE ME SOME HINTS ABOUT CHANGING OUT MY FUEL FILTER? THERE REALY ISNT ANY ROOM DOWN THERE TO GET TO IT...AND I AM BURNING WAY TO MUCH GAS!!! THANX FOR THE HELP...MATT
..remove fuel line from fuel pump (right side of bike)
..walk to the other side of bike
..pull fuel line (including filter and the piece of fuel line you just detached from fuel pump) 'through' the bike and pull out at left side of bike
..you now have the filter 'outside' the frame and you can easily
replace it
..re-mount fuel line to fuel pump
EDIT: sorry; didn't see Q's post.
Da' Supercharged Bulldog
Antoine de Saint-Exupery
- Zacsdaddy
The fuel filter bracket is held in place with a 10mm bolt. I use a screwdriver handle with a socket. A 6" or so extension will reach it also.
Zacsdaddy
Zacsdaddy
1981 GL1100 That Mama found and bought for me.
1975 KZ400D That I found for Her and brought back to life.
"If the Women don't find you handsome, they ought to at least find you handy" - Red Green
Related note:
When my bike was losing power..I first looked at the filter...and yep..plugged. I couldn't find a stock sized replacement..so Auto Zone had a much smaller one..resorvoir about 1/5 size.
I did the Dyna conversion.
The bike ran much better but it would have a flat spot at 3500..to 5000..then just great.
I was going to strat looking at retiming..carbs. I repaced the small filter with the correct size..and
OH MY..!! Absolutely excellent now.. I think it would fuel starve..and work well after the gravity feed could supply enough to the pump.
USE THE CORRECT FILTER..sometimes it's the little stuff..
..oh no..he's not here..he's out riding...again...
[url=http://www.nakedgoldwings.com/gallery/Doccs-Ride][u]Docc's Bikes Album[/u][/url]
'76 GL cafe (owned since new)
'02 VTX 1800C
'02 VTX 1800C
