slight oil burning at start up, NORMAL?
- semerm
I have a 76 gl1000 that I have put about 250 miles on the bike so far (new to me) but the clock says 45000 miles. It has just started to puff a little oil at start up. Afterwards it does not do it (after 30 seconds or so). Is this a sign the rings are suspected, valves? any way to tell without a engine pull?
That is very normal for these bikes. I just replaced my valve guide seals and mine has stopped for a while but it will be back. That is the nature of a horizontal engine. Nothing to worry about. Sometimes parking on the center stand can reduce it some.
- rvtechA1
I agree With WF, Mine puffs sometimes, sometimes it dont
This is normal.
if the oil needs changing, doing that may help some too
at that milage, check your U Joint, Mine Just broke at that milage.
its under the rubber boot by your right heel when on the bike.
very easy to see.
This is normal.
very easy to see.
Jim
LED Nights
LED Conversion Lighting For your Gold Wing
jim@lednights.com
[url=http://www.lednights.com/][img]http://www.crescentmoonunlimited.com/assets/images/LED_Nights_small.gif[/img][/url]
Bikers For Christ Member
http://www.bikersforchrist.org/
LED Nights
jim@lednights.com
Puffs
Comes and goes
- Lead Member
