Page 1 of 1
CX500 Broken timing chain
Posted: Sun May 15, 2011 1:43 pm
by thunderchild
Hay guys,
I'm thinking on looking at a CX500. The guy told me it has a broken timing chain. Would this had harm the motor in any way. I know if a belt brakes on a GL1000 it can but what if it's on a CX500.
He asking $300 as is.
Re: CX500 Broken timing chain
Posted: Sun May 15, 2011 3:19 pm
by Rat
Could , likely would, bend valves at least.
Posted: Sun May 15, 2011 9:39 pm
by hmratbam
I wouldn't go into it without figuring on an engine. Good timing chains in healthy engines are not prone to breaking,I'm guessing there are other issues?
Posted: Sun May 15, 2011 10:33 pm
by thunderchild
Have not seen the the bike yet. Guy is too old to know how to send pics of bike. I'm waiting on his email reply.
Posted: Sat May 21, 2011 12:53 am
by jinbtown
Chances are you've got some buggered valves...
but that being said, the tensioner is notorious for *not* being adjusted properly, too tight or too loose.
Given the fact that I've bought several running CX's for <$200, I wouldn't pay a dime over $100 for this one *unless* it's in mint body condition with side panels, original seat, etc.
Posted: Sat May 21, 2011 8:09 am
by Rat
thunderchild wrote:Have not seen the the bike yet. Guy is too old to know how to send pics of bike. I'm waiting on his email reply.
Hey .... I resemble that remark.
Posted: Wed May 25, 2011 9:56 pm
by Sidecar Bob
Usually, one of the camchain guides lets go and it makes a noise like a diesel on a cold morning before the chain itself breaks, but I can tell you from experience that CX camchains do occasionally break. Mine was the 650 engine I had in my 500.
When a camchain goes you really should at least take the heads off and make sure the valves are straight. I decided I didn't want the bigger engine enough to spend the extra $$ so I put a new camchain & guides into the original engine and parted the 650 engine out. Wouldn't you know - when checked the valves before putting the heads on eBay, all of the valves were fine.
But you can't count on that being the case.
On the other hand, even if the valves are bent, you could easily double your money parting it out...
