Aftermarket Carbs
shieldsm
Aftermarket Carbs
Post by shieldsm »
Some advice,
Maybe thinking about buying some aftermarket carbs (Weber or Holly). Wondering if there is a huge advaantage to these and what models are your best bet. Looking at maybe the Weber IDF40 with Raadak's manifold mod?
Re: Aftermarket Carbs
not a huge advantage, but will increase HP. Randakk has a complete breakdown on using his manifolds..
Moved this to the Unique Carbs forum.
earthquake
Post by earthquake »
Has any body ever used a set of Dellorto 36mm DRLA's on a wing before? they are a little harder to get parts for but are easier to tune then 36 IDF's. 36mm IDF's were never imported in the US in any quantity and were a factory carb used on Fiat's and some other European cars and had a few minor differences then regular IDF's, but Dellorto 36mm were sold here through CB performance for the VW crowd for use on the smaller motors. with the smaller throats it would get port velocity up which should run a little better, but you might have to make the manifold runners smaller at the top to take advantage of it. Dellorto DRLA's have the same bolt pattern as Webers so they are interchangeable with IDF's but unfortunately they are no longer made as far as I know.
Casey
"If it shines, bends, bangs or clangs, ITS METAL!!! and if I cant work it, I"ll piss on it!"
I love Boxer engines be GoldWing or VW
http://www.rememberingkelly.com/
TCNFast
Post by TCNFast »
You should also check-out the place where I got my manuals at JESSCO motorcycle. They got manifold and carb stuff also. I'm thinking of changing my carbs too. I cant start my bike and keep it running because the carbs are messed up. There pretty expensive.
TCNFast wrote:You should also check-out the place where I got my manuals at JESSCO motorcycle. They got manifold and carb stuff also. I'm thinking of changing my carbs too. I cant start my bike and keep it running because the carbs are messed up. There pretty expensive.
Yea if you read their page they will sell you what every you want if you buy 10 at a time.
Group Purchase Available NOW! - Spring is Here!
Our Group Purchase Policy currently does not allow for individual sales. With every Group of 10 Pre-Paid Sales we ship within two weeks.
So why would a manufacturer develop a product and sell it only in lots of 10?? My "guess" is because the product does not exist and he really does not want anyone to order it. :dunno: :dunno:
The guy running that site was banned from here for being a known liar in the promotion of his site.
Hoosier Daddy
Post by Hoosier Daddy »
When did we get a "Unique Carb" section?!?
Huh, learn something new everyday.
rainstromrider say's I'm "addicted to the build"... I think he might onto something :)
Post by HOTT »
Ha HD ! lolol '60's good to you too ? Uh um... I prefer Webers. And I don't even know why.
Hoosier Daddy wrote:When did we get a "Unique Carb" section?!?
I had to go look but I found that it was started 27 April 2010. So it only took you 11 months to find it lolol lolol lolol lolol
Hoosier Daddy
Dang child threads... I'll chalk it up to the fact there is SOOOO much info here on NGW that you can never read it all.
Yea, thats it!
:roll: :roll: shakehands
gregforesi
Post by gregforesi »
The dual weber conversion is discussed in this thread Dual Weber Conversion Conversation
I know nothing about stock carbs but I know a bit about the Webers if you have questions.
2006 GL1800 (Brutus Maximus)
TCNFast
Post by TCNFast »
that's interesting. I didn't know that. I called them and talked to steve about buying a carb and manifold for my bike. he said hes got 7 sales and needs 3 more to sell. said he sells in groups of 10 so your right but i think not all the way. they have carb inromation on lots of carbs for cfm but the calculator don't work. said they working on it. I might just get onlt the manifold. i got a carb. he got bannedhere for lieing?
It's a VERY long story...
Good wrenchin'
Todd
78AZWing
Post by 78AZWing »
You could always built your own outa pvc piping from home despot.
Quite a few people have done so.
http://www.htc.net/~squirts/plastic.htm comes to mind.
For that run-down feeling -
Try Jaywalking!
1978 'Wing with Weber conversion, UnDressed
1976 Junkyard 'Wing with a Dyna ignition. Otherwise undressed.
Proud member of the "NGW CARTEL"
