Weber Jets
vagrant50
Weber Jets
Post by vagrant50 »
Anyone running a 32/36 Weber on a 1200 who has had it for a bit and has it dialed in. What is your jetting sizes?
Brent
I can build anything you can afford!
http://community.webshots.com/user/vagrant50
SJBikesaws
Re: Weber Jets
Post by SJBikesaws »
Same question here. I am looking for some base line jetting for my 32/36 mounted on my GL1100. It would also be nice to know the elevation where you obtained you perfect jetting.
I'm trying to avoid buying 2 dozen jets and pulling it apart that many times. If I can find a close starting point, maybe I will only have to pull it apart 3 or 4 times.
Sean
Gotta 81 GL1100 Rat rod, not what Honda meant to build, but what I have always wanted.
