When I bought this 81 model GL 500 a few months back the seller stated he had just serviced everything , changed the oil and filter , new air filter and oil in the front end . I forgot to ask him did he know what he was doing . The front end sprayed oil out onto the radiator for two weeks before stopping, obviously he just filled it up without knowing it was supposed to be filled with a pre-measured amount .
I tried several times to fill it with air as this one has a front end like a goldwing has , under air pressure. Well it would hold air for a few miles sometimes a day or two but always leaked down .
A few days ago I checked the air in my tires and thought what the heck , so I again put air in the front end , more than it said to and that sucker has not leaked yet ! I was prepared to take it apart and rebuild the forks, a job I was not looking forward to doing.
I wonder why all of a sudden it is working right.
							frontend
- the chef
- Location: Odenville,Alabama. The land of dixie! (!Hell yeah!!)
frontend
On the highway to Hell!
Ride on, Ride on.. !
PREVIOUS OLD LOVES=
19?? Zundapp with 6 hp Briggs and Stratton engine Chrome tank
1971 Kawasaki H1 500 blue /white stripe
1975 Honda 750 Yellow
1980 Honda Gl 1100 Interstate Black
1982 Honda Gl 1100 Standard Black
1983 Honda Gl 1100 Aspencade Black
1981 Honda Interstate Black
1981 Honda Gl 500 Silverwing . Candy muse red
1986 Honda VT 500C red
PRESENT RIDE >1976 Honda Gl 1000 Originally red, now flat black, olive drab, primer gray.
PREVIOUS OLD LOVES=
- Hoosier Daddy
Re: frontend
Maybe the increase in air pressure finally seated a seal that was not in place?
Or maybe Karma is smiling and you should buy a lottery ticket.
Re: frontend
Maybe it stopped leaking fork oil because .....
Gord (none is not enough) Jones
'13 Honda NC700sa … TNG
- the chef
Re: frontend
Surely it couldn't have squirted it all out , do you think it just got rid of the excess?
PREVIOUS OLD LOVES=
PREVIOUS OLD LOVES=
Re: frontend
Easy to check.
Do they still work?
							Do they still work?
				Papa Bear
Re: frontend
I have drained some pretty empty front ends. As a matter of fact, virtually empty. I'd inspect the front brakes, too, if you haven't already. If you were leaking, chances are, they are contaminated. If they are, change them. Cleaning doesn't work.
Since you don't know exactly what the PO did and you know he did it wrong, I'd drain the forks and clean them well and fill properly. You don't want a weak front suspension for many reasons not the least of which is good braking. A weak front end compromises braking quite a bit amongst other things.
Papa Bear
Keep your head on a swivel and your eyes open!
Current bikes: '78 Wing with '76 false tank, '76 Wing (GLzilla) with 1200 bottom and 1000 top end, '82 GS850 beater bike. '84 1200 project motor.
Previous bikes: '72 Yamaha 250, '76 Kawi KZ400, '62 Triumph 650 Bonnie, '74 Triumph (Chopped), '78 Kawi 750 Twin, and '76 GL.
- Hoosier Daddy
Re: frontend
I thought the chef meant it stopped leaking air and now holds good pressure...
- the chef
Re: frontend
It did stop leaking air , brakes work fine.  I was just wondering how much oil is in them now , but I will drain and refill sometime ,  but they work better now than ever before.
PREVIOUS OLD LOVES=
PREVIOUS OLD LOVES=
