This may help some people out or at least save them some money if they are naked-ifying (that's my made up word for the day) their GL.
I did this as a temporary fix for test riding after trying to find stems.If bone stock is not a concern, JP Cycles sells the replacement lights pretty cheap. These lights have a ~ 1/2" inner diameter stem with bolt to clamp onto the mount. The forks of my GL 1000 had a threaded hole which was 1/4" diameter.
The solution. I went to the hardware store and bought two 1/4" threaded pipe nipples about 1" long and two 1/4" to 1/2" threaded adapter. The turnsignal slides over the 1/2" side and clamps with the bolt onto it, then the 1/4" nipple is screwed in to both the adapter and the forks. The end result places the turnsignal light right off of the forks with the wires hiding inside the stem. Nearly stock looking for less than $5 of plumbing supplies.
Hope this helps.
Sam
GL 1000 Turnsignals
- Try
- NGW Founder
- My Album: http://www.ngwclub.com/gallery3/index.p ... wing-album
Re: GL 1000 Turnsignals
Hello Sam, thanks for sharing!samarnold55 wrote:This may help some people out or at least save them some money if they are naked-ifying (that's my made up word for the day) their GL
Sam
Try
"84 - GL1200 Standard
Try
- roncar
I just did pretty much the same thing except I used OEM turn signals. Thought I was clever. Then found this thread from 2 1/2 years prior.
My results with pictures.
- RogueCreature
this seems like as good a place as any to post this....
shouldve asked around first...so not good at that
anyway..... on the 77' left rear blinker out. figured f it and bought all the lights...
got back..broke one of the bulbs i didnt need (DOH!)
annnddd i thought this switch would be easy....i pulled the boot out of the metal socket area and the wire wasnt as free as i thought it would be.
what do i from here how do i fix this?
wrong bike not to be mechanically or electronically inclinded with....but I LOVE IT.
any help appreciated
1977 GL1000 Once upon a time
Some have said i have the patience of a rock. I know myself to well to say the same.
