Which Windshield?
Russ in California
Which Windshield?
Post by Russ in California »
No dought I need a windshield. What kind and brand do you guys run?
Probably go thru JC Whitney or Dennis Kirk. Searching, searching...
Frame mount or handle bar mount?
I DID look thru the pics but not many good pics of the windshield and mounting.
Thanks,
Russ in California 8)
1976 GL1000
Humboldt County, California
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants."
Thomas Jefferson
Try
NGW Founder
NGW Founder
Re: Which Windshield?
Post by Try »
Russ in California wrote:No dought I need a windshield. What kind and brand do you guys run?.
I like the handle bars mounted (with clamps), very easy to mount on/off.
Try
"84 - GL1200 Standard
anim-cheers1
BLUE82
Lead Member
Lead Member
Windshield
Post by BLUE82 »
Russ, I used a Memphis Shades Windshield for a Honda Valkyrie. It seems to be the right size for my GL1100. The headlight cut out had to be made a little deeper. I then used the headlight ear bolts with the thread in the head of the bolt to secure the lower portion, and made up some aluminum arms to fasten the upper portion to the handlbars. Works well and looks good too.
Zryder
Post by Zryder »
Hi Russ , listen , if you go to my album in the Wingmans Lounge to Zryders the first three pics will give you a good idea as to what the mounting brackets are and where . Handle bar and fork mounting brackets , quite solid .
Zryder crosso
