I'm installing the caliper and bracket assembly back onto the forks.
I noticed that the lower caliper bracket bolt was protruding thru it's hole and into the raceway where the rotor should only occupy.
OH! That doesn't look right.
I thought well I had some spare brake parts from a '78 and maybe I got something mixed up. So I removed all the bolts and looked them over.
Apparently there are long ones for the upper mount and VERY SLIGHTLY SHORTER ones for the lower mount. An I mean really slight. You could find one short and one long and the difference is like two threads.
Look I thought this would be important so I just stopped and took some pics of the calipers mounted both ways and pics of the bolts. So have a look.
the longest and the shortest of the whole lot. Most were more nearly the same.
I know some of the pictures are a bit blurry or dark but hey I was in a hurry.
