PIPES!!
TINBASHER
- Tin Member
PIPES!!
I don't know if any of you know about this, but that horizontal four actually sounds pretty sweet running through straight pipes. I want to do that to mine, but I want to make sure I run it through a big enough pipe so it's not quite so loud but still rumbles. Of course, I want the ol' girl to be able to breathe well too. Any ideas? 8) [/b]
- RebelRouser
- Webmaster (Retired)
- My Album: http://www.ngwclub.com/gallery/v/wingmans/rebelrouser/
Hey Tinbasher;
You do need to have back pressure to run properly so complete straight pipes are not a good idea, atleast two baffles will give you enough back pressure here are some drag pipes for the GL's
http://www.jcwhitney.com/autoparts/Brow ... 15/c-10615
http://www.jpcycles.com/productgroup.as ... DAAAB81968
as well as two of our parts gurus here BIG T, and FRENCHY
Hope this helps
Rebel Rouser
Hope this helps
Rebel Rouser
- Try
- NGW Founder
- My Album: http://www.ngwclub.com/gallery3/index.p ... wing-album
Re: PIPES!!
Hello TINBASHER, check also out Muffler topicTINBASHER wrote:I don't know if any of you know about this, but that horizontal four actually sounds pretty sweet running through straight pipes. I want to do that to mine, but I want to make sure I run it through a big enough pipe so it's not quite so loud but still rumbles. Of course, I want the ol' girl to be able to breathe well too. Any ideas? 8) [/b]
Try
"84 - GL1200 Standard
Try
