GL1100 Chrome radiator shields... fit a GL1000?
phaserburn
My Album: http://www.ngwclub.com/gallery/v/wingmans/phaserbu
Post by phaserburn »
Hi,
I am looking to replace my (once) painted GL1000 Radiator shrouds with chrome ones from the GL1100. Are these a direct fit?
Thanks!
1983 Honda GL1100 Bagger
2015 Super Tenere
2018 Ducati Desert Sled
http://www.ngwclub.com/gallery/v/wingmans/phaserburn/
About 95% sure thay are but wait for 100%.
I'll tell you in a couple days, as I am tearing down the 1100 this weekend.
RebelRouser
Webmaster (Retired)
Webmaster (Retired)
Post by RebelRouser »
Yes It's A Dead On Match, Put 1100 Ones On My 75 GL1000 And Brant Put The 1000 Ones On His GL1100... I Also Put A GL1000 Rad Into An 81 GL1100 Same Thing...
phaserburn
is the gl1200 radiator a direct fit onto the GL1000 series?
2015 Super Tenere
10-4 on the shrouds..
RebelRouser
Webmaster (Retired)
Webmaster (Retired)
phaserburn wrote:is the gl1200 radiator a direct fit onto the GL1000 series?
No... The 1200 Rad Is Different Than The GL1000/1100, 4 Bolts To The Fan, No Shroud Mounts, No Upper Bolts- Rubber Gromets Instead, Size Wise I Belive It Is The Same, So With Some Modifications It Could Work, But It Is Not A Straight Drop In...
