squealing sound small timing belt pulley
trav
Rusty Probie
Rusty Probie
Post by trav »
I could use help on finding a problem with a 1100 wing. I have a chirp or squeal coming from the small drive pulley for the timing belts. the belts are almost new with 5 or 6 hundred mi. on them. I used stethoscope to locate which pulley the noise was coming from. After removing the radiator and belt covers I started the bike and let it idle, the chirping starts not long after and is not continous. To me the belts seems to bounce around a lot, the tensioners seem to be alright. Hope some can help. THANKS TRAV
QUEEENlE
Post by QUEEENlE »
Welcome to Naked GoldWings trav ...nice to have you here. Im sure that someone will be along shortly to help you with your issues. Jump into the other forums post your questions, comments, concerns and your two cents....again welcome to Naked GoldWings ..stay safe and ride naked... i do.
Q
Bandanna
Post by Bandanna »
from what you describe, the sound could be the tensioner pulley bearings.
they have 2 nuts to secure them on each..
has the nuts gone slack on either?
because the centre pulley(crankshaft end bearing) would be the next item. especially if noise coming from centre..
i would re-check the tensioners,as i feel this is what is making the noise.
the noise could be being transferred by the belts,making it seem elsewhere..........
is the engine oil level ok??
keep us posted+welcome to naked wings..............
safe riding....................all
