What Did You Do To Your Wing Today?
Re: What Did You Do To Your Wing Today?
#9361
Got a new battery and took Layla out for the first ride of the season. Spent an hour playing in an empty parking lot warming up my riding skills (and the tires, and the foot pegs a few times, lol), then took an easy cruise. Some back roads are still sandy from our last rain/ ice/ snow, so no curve carving today!
#9362
Rat wrote: Fri Mar 28, 2025 9:24 am I think we’re pretty sure it’s not a piece of junk … take a nice picture … we need a BOTM …
lolol lolol lolol lolol lolol lolol lolol
She is no beauty queen for sure. I do have on picture of Old Fogey riding her on the Dragon I believe but that was with the stock exhaust. Hard to believe that it has been 15 years!!!
I did ride out to Windsor and get a tank of Fresh Gas in it. Seems to be running good.
I did not do a top end run but up to 90 or so she pulls steady and hard.
#9363
Nice bike for sure.
#9364
interesting.... comstar wheels and a 78/9 exhaust... but 75-77 body panels
#9365
Johnny Cash's bike
#9366
Front end is 78, exhaust is early 1000 just powder coated a light grey, tail light is 78, rear fender is HD. Frame is 75, engine I think is 77. I lost track she has had a few engines. Here is a thread devoted just to that viewtopic.php?t=27436&hilit=engines#p262696
OhioBill
My Album: http://www.ngwclub.com/gallery/v/wingmans/OhioBill
#9367
Post by OhioBill »
I installed a Lithium battery in my 78. The reduced size allowed me to have a power distribution box beside it so I could clean up all the wires that were going to the battery posts. The battery despite it small size still has 350 cold cranking amps and only weights about 2 pounds.
Also stripped the forks off a 1200 that I purchased for parts. May eventually install on my 78.
OhioBill
Retired and Loving it.
1979 Black (to be restored)
1979 Blue (Sold)
1993 blue 1500 Sold
1976 Restoring
#9368
That will be a nice upgrade
todd54219
#9369
Post by todd54219 »
Time for some needed maintenance. Needed to do belts. While I had the radiator off, time to put the original hose clamps back on. Also time for new coolant. I try to replace it every 2-3 years. While I was down this far, I decided to adjust the valves, along with new valve cover gaskets. The main reason for all of this surgery was to repair leaking float bowls. I have about 6 -8 screws that were stripped and I had put in oversize screws. Last fall I noticed some indication of some leakage so off with the carbs. I am thinking of HELICOIL's. Maybe just re-tap for the next size up on the screws. Still trying to make up my mind which to one.
Need to decide and get it done as the weather here in Kansas CIty is warming up and I am ready to ride.
Todd
1976 Yellow GL1000
#9370
Tough decision Todd, might do well to get another rack but that might come with a another set of problems. I feel your pain.
todd54219
#9371
Post by todd54219 »
Fred, it is not an easy choice. I do, however, have another old carb rack to test my choices. As you mentioned, I do not want to find a whole different rack. I do not want that can of worms. One way or another, I will fix my problem.
More to follow. I am going to the parts store to get a Helicoil kit and see what happens.
Todd
1976 Yellow GL1000
#9372
IMO, the worst thing a person can do is put over size screws in the bowls. I've seen too many go through here like that. The best fix, not the cheapest, is to use time-certs. Of the correct size of course. They are fixed almost permanently that way. Helicoils in a pinch but any carbs that go through here with stripped bowl screws get time-certs.
#9373
todd54219 wrote: Wed Apr 16, 2025 9:59 am Fred, it is not an easy choice. I do, however, have another old carb rack to test my choices. As you mentioned, I do not want to find a whole different rack. I do not want that can of worms. One way or another, I will fix my problem.
Todd
viewtopic.php?p=830194#p830194
#9374
Cliff has another method worth trying first. It still allows you to use time-certs later.
#9375
Good luck!
Return to “NGW Club House”
