A '75 followed me home today
roncar
Re: A '75 followed me home today
#46
Post by roncar »
evilratwing wrote:... but if I found one with 5,500 miles on it... I'd be obliged to return it to as-new condition.
As I pointed out in another thread, the time, money, love that you put in does not usually equal an exponential profit when reselling. NOS parts are no longer NOS once installed. And unless you plan to keep it parked, 5500 miles won't be it's mileage for long. There is also no guarantee that's the original speedometer nor that the mileage isn't 105,500.
wog wrote:My plans for this bike is to make it a rider. I want to keep it with the stock look, with probably the current engine guards and maybe the rear rack as those are what the original owner had mounted, I guessing when new....
I've never wanted a "museum piece" kind of a bike but if you guys feel I shouldn't change out the frame with another, I'd definitely consider keeping it untitled with the current everything...
As for the personalizing of bikes, one of my '79's came to me with a single carb conversion. I haven't started on it yet, but my plans are to make it my "wild child".
If you want to make it a rider, you have to be able to legally put it on the road. While titling the original frame may be possible through title agencies, the process is, IMHO, expensive. I don't have the money for that and really suspect any 'value' to be gained, will not be seen due to the cost. Besides, it's not like your frame is a low serial number or has any specific significance or value.
I figured out long after I got my '76 (and after a frame swap and joining NGW,) that it has a '77 engine. I don't have the original frame, but in reflection suspect it was was also a '77 due to the steering neck diameter difference compared to my current '76 frame. Mixing and matching of parts is, a lot of the time, undetectable to the untrained eye. Still makes a nice looking vintage bike without breaking the bank.
Bottom line, IMO, an untitled bike is a parts bike, at least in Florida.
wog
#47
Post by wog »
Starting back on this project. :IDTS:
I've picked up the replacement frame from Roncar. He also was kind enough to work his magic on getting the original key to fit in another ignition switch.
Before I send the frame to the blasters to be stripped, I'm going to remove the frame side bar and any other items that will be powder coated. I need to do a little welding to fix the centerstand mount on the replacement frame, but I'll wait until it's blasted to see if any other holes show up for the party.
So nice to see a bike this old with only 5500 miles, as all the wiring, etc is original. No splices for the Christmas lights that were so often added. (Yes I did it too back in the '80s). :oops:
Even the fusible link is in good condition.
Question for you guys with spoke wheels...
There is an oval sticker on both wheels that has the rim size and "D. I. D"
No mention of "Honda" on it. I'm guessing they're original.
Easter
#48
Post by Easter »
D.I.D. was/is a regular supplier to Honda (had them on several bikes) so I am pretty sure those are original.
83 GL in process :IDTS:
#49
Original, so keep them if you can. I think I remember that Placer had some duplicates made if you need one. I could be wrong though.
wog
#50
Post by wog »
thanks guys.
Will definitely keep them as they're in great shape.
wog
#51
Post by wog »
Guess I have a little engine work ahead! :IDTS:
El_Taco
#52
Post by El_Taco »
Oooh, crustiness... I assume you've turned the motor over already. I've found some really pretty bikes locked solid. Either way, great find. That's going to make for one nice daily driver.
wog
#53
Post by wog »
It's locked solid.
But will be on the road. :crosso
#54
Looks to be worth the effort. Keep at her.
wog
#55
Post by wog »
Today I used a spray on paint stripper for the replacement frame before sand blasting it. Worked great. Just hosed it off with a pressure washer and there was little paint left for blasting.
The removable frame section from my bike is in great shape. Solid as can be.
No other rust holes showed up on the replacement after blasting, just the two areas I knew about.
I'll fill the one on the top and maybe add a small gusset for support.
The center stand mount is very thin at the cross section. Haven't decided if I'll just reinforce it, cut out that section and replace with the original's, or just remove the whole stand mount and replace with my original.
I'll add two zerk grease fittings.
There was a very rusty area in the front lower corner, but no through holes. I tapped the craters with a punch and it seemed solid. I might add some filler metal over the surface and grind it down.
Next week... to the powder coaters action1
#56
Good progress. I like the concept to reinforce those thin spots.
klux182
#57
Post by klux182 »
..Looks like you found a great one too. Mine wasn't locked-up. Sorry yours was.
wog
#58
Post by wog »
I was hoping the frame would be back from the coaters today but no luck.
I was excited about getting into the "virgin" set of carbs, but now not so much. Here's the worst smelling, darkest orange gas I've ever removed from a bike! :shock:
wog
#59
Post by wog »
Here's some of the welding done...
Decided to try just welding the cracks/gaps in the center stand mount.
Had a couple of blow-throughs in the first stage, but it worked out and sanded down fine.
Plenty of metal there now.
wog
#60
Post by wog »
Lower front corner...
