BTW I had to go look up Kludgy, I thought you was making that one up there Deek
+1 for the Megasquirt MegaManual: http://www.megamanual.com/mtabcon.htmIS THERE A HOW-TO BOOK or some Hot Rod Magazine primer on fuel injection for those of us who do not have the time to study 25 different sources or the time to pick up a clue at a time here and there?
Over here, cludgie is a Scottish east coast word for toilet!Whiskerfish wrote: BTW I had to go look up Kludgy, I thought you was making that one up there Deek![]()
Old Fogey wrote:Over here, cludgie is a Scottish east coast word for toilet!Whiskerfish wrote: BTW I had to go look up Kludgy, I thought you was making that one up there Deek![]()
We used to say "Mickey Moused".we used to say "jury-rigged"
I think it will. There is no drop of voltage when You don't use the starter, that means the computer does not need to raise the injector power. But I did not test it so far.hi...ive been following this with some interest.....i like the idea and hope it really works out....i have a 75 gl1000 with the kick start....do you think the FI will work with the kicker?
If he's triggering off the ignition system, that won't be a problem.jap4lvr wrote:the problem is with kick start and a trigger wheel. sometimes you cant spin the motor fast enough for the computer to read the trigger well enough.
The components look somewhat familiar, but I've not seen them in that configuration. The pump isn't familiar, though. See if you can track down a schematic (Chilton's or Hayne's) Then you can learn something about it.taunusrainer wrote:Does this pump/reg/Filter setup look familiar to You? It is GM, Opel Calibra 16v.
If you remove the mechanical fuel pump, you would have a natural place to put a trigger wheel on the exposed end of the cam, I think.All you need to do is put a trigger wheel and sensor on the snout of the crank or the end of one of the cams.
