The New Intake Prototype
badorderbob
Re: The New Intake Prototype
#31
Post by badorderbob »
The oil conversion has been done by Ray T. in his manifold build where the line ran directly thru the plenum. And you could also use coolant. :orange So it has been done but I believe if you want HOT then go with coolant if you can!!
Robert White
