GL 1000 cafe fighter
EHE
Re: GL 1000 cafe fighter
#241
Post by EHE »
Thanks again.
These machines were my wish ever since i was a kid... And now i m almost 40..
For over 25 years i ve been working and saving money to buy tools and machines and it will continue as long as i m not too old to work with them. :)
EHE
#242
Post by EHE »
braking time :)
it turned out that I had a wonderfull combination laying around.
an aftermarket wheel for a GL 1000, ZZR 1100 front end, Braking calipers from a Fireblade and discs from a Ducati make a nice match and just needs some spacering/ adaptering
EHE
#243
Post by EHE »
I never knew that a GL wheel is assymmetric...
allthough the discs are exactly the same the hub is on the left side 4 mm wider then on the right...
if fixxed it in the adapters so now everything is symmetric,
Old Fogey
#244
Post by Old Fogey »
J Wright wrote:im liking it. I wish I had access to machining equiptment
oh, me too, me too! Some great ideas here, very well executed.
Easter
#245
Post by Easter »
Is that to be a single rotor set-up? Looks great.
83 GL in process :IDTS:
Old Fogey
#246
Post by Old Fogey »
EHE wrote:I never knew that a GL wheel is assymmetric...
if fixxed it in the adapters so now everything is symmetric.
Could that not be down to the width of the speedo drive?
You would probably find the later Comstars are the same for the opposite side, with the drive on the left.
EHE
#247
Post by EHE »
Easter wrote:Is that to be a single rotor set-up? Looks great.
No, double set up
Lets try to make stoppies with a goldwing lolol
Easter
#248
Post by Easter »
No, double set up
Put it on U-tube, I'll watch dancr
EHE
#249
Post by EHE »
i m more into facebook currently ;)
but I keep on going :)
removed this old and non damping shockabsorber
by a new one
fitted in very easily. only needed to replace bushing in the lower mounting point and add two spacers to the top mounting
Now modifying the frame to fit the 1200 engine
first i was thinking of adding a curve in the tube and keep the Original position
but moving it upwards for an inch seems more simple and better looking
but i m worried about the stiffness of the rear end, so I m considering of taking a look tonight if I can replace the one tube by two crossing tubes holding also the pivot point of the swing arm
Or I will keep the horizontal one and add a few triangles towards the pivot point.
depends on which option looks the best
EHE
#250
Post by EHE »
this is how it ended
but first I modified the swingarm to avoid it intervering the ignition module
then added the triangles so I'm sure i can still get the swingarm in and out
Easter
#251
Post by Easter »
looking great!
5speed
#252
Post by 5speed »
impressive fabrication.
wingrider
#253
Post by wingrider »
That is certainly one way to deal with the 84 ignition problem! Great job!
EHE
#254
Post by EHE »
I dissambled the crashed sidecar this weekend so now I have a good comparison between a the new frame and the "Original" one
the frame is as far finished now that the 1200 engine fits in smoothly. so no I can continue the puzzle
#255
Looks awesome so far. You must be pretty well healed up.
