The NGW Project Bike. Body/frame/style
Locked
octane
#241
Post by octane »
Try wrote: Lars, I don't have words, amazing charger.
Hi Trygve!
Yes it's a beautiful piece of machinery .
The Weber has been rebuild.
Not much to say about that, except my old mantra:
do a cardboard replica of the carb
to insert jets, emulsion tubes, etc.
so you can keep track where they belong:
I've messed around with the covers to see if I can come
up with some sort of solution to cover the extra belt.
....the whole thing has been squeezed into the frame
(after having to cut out the cross-member just in front
of the gas-tank)
still have a few things to fix.
Alter the bolt that holds the extra pulley,
cut out a piece of the false-tank 'body'
to make room for the Weber :
Does seem to 'belong' there, doesn't it ?:
WROOOOOOOOOOOOOOOOOM .-)
Da' Supercharged Bulldog
Antoine de Saint-Exupery
Frenchy
Post by Frenchy »
I can hardly wait for the video of you ripping up the pavement with it!! :twisted:
Frenchy
RebelRouser
Webmaster (Retired)
Webmaster (Retired)
Post by RebelRouser »
I Invision A Cartoon, The Pavement Being Folded Up Under The Rear Wheel As He Rips Into It..... Looks Great in My Mind....
Try
NGW Founder
NGW Founder
Post by Try »
octane wrote: Hi Trygve!
There you have some good rules to keep everything as it shold be..
octane wrote: I've messed around with the covers to see if I can come
Maybe customize a stock cover, if you has a MIG welder to tackle the job...
octane wrote: ....the whole thing has been squeezed into the frame
of the gas-tank)
Not mutch space again there Lars, really a tightfit look. Will the radiator fit?
octane wrote: still have a few things to fix.
Looking forward to see more pics of your great project Wing,
octane wrote: Does seem to 'belong' there, doesn't it ?:
I'm pretty sure it belongs there :lol:
Thanks
Try
Try
"84 - GL1200 Standard
anim-cheers1
octane
#245
Post by octane »
Hi Try.
Yep that's exactly what I had in mind
octane wrote: Not mutch space again there Lars, really a tightfit look. Will the radiator fit?
Yes, it's supposed to fit, but has to be moved a little forward.
There won't be room for the standard cooling-fan.
The set came with a pair of small fans that I do not want to use.
I'm looking at some modern 'flat' fans where the electric motor
doesn't take much space, as it's build into the center of the fan,
like this Kenlowe:
..they are a lot more effecient that the standard fan,
as they have more 'blades' and larger fan-blade surface,
so a smaller diameter will do the same (or better) job.
Try
NGW Founder
NGW Founder
Post by Try »
octane wrote: Hi Try.
Very intresting Octane, the stock fan is a big cake :lol:
Looking forward...
Try
anim-cheers1
octane
#247
Post by octane »
Well well
Slow progress here, and sort of digging into details;
can't really find a motorcycle-fan slim enough to fit in.
There's VERY little space.
So decided to check those old crappy looking fans that came with
the original blower set-up:
..and they turned out NOT to be so crappy after all;
I bought a new modern (PC-type) fan of the same size as these
and to my surprise the originals were hugely more effective,
and all in all functioned rather well.
Surprising after 27 years of being exposed to all kinds of wether.
Heck: fixing up old stuff is SO much more fun
than using money on new stuff !
so took them apart to check them.
They're really nicely made. Real metal and aluminum,
no plastic crap,
and revolving on a set of real roller-bearings
Look at that;
thats one VERY small roller-bearing (and it's in fine working order):
Gotta fix them up nice; so here they are after blasting:
BTW;
got a good offer from a guy I know, who distributes Indian parts,
for a set of Double White Wall tires.
Old-style tread pattern, but modern kevlar inforced construction
and approved for 210 km/h. (130 miles/hour).
Had to try'em on:
mmmmmmmmmmmmm....donno
Try
NGW Founder
NGW Founder
Post by Try »
octane wrote:Well well
Had to try'em on:
Very nice work on the Wing Octane, You’ve made a great
style on it. Keep us posted, thanks.
Try
Try
anim-cheers1
octane
#249
Post by octane »
Thanks Trygve!
To add a little lubrication to those tiny bearings,
I used this rather amazing stuff;
it's made for them modern O-ring chains and
comes in a spray can.
When sprayed it's so thin it's able to penetrate even pass
O-rings...and after a while it 'dry' up to a thick
grease-like substance.
Great for getting grease into closed bearings.
I put the bearings in a 'bath' of this stuff.
Here it it after drying up:
Oh, one can spend a LOT of times on these small details
but then again; I find it so satisfying to turn old crap
into old 'good stuff'
the chef
Location: Odenville,Alabama. The land of dixie! (!Hell yeah!!)
111
#250
Post by the chef »
AWESOME!!!I want one! chef
On the highway to Hell!
Ride on, Ride on.. !
PREVIOUS OLD LOVES=
19?? Zundapp with 6 hp Briggs and Stratton engine Chrome tank
1971 Kawasaki H1 500 blue /white stripe
1975 Honda 750 Yellow
1980 Honda Gl 1100 Interstate Black
1982 Honda Gl 1100 Standard Black
1983 Honda Gl 1100 Aspencade Black
1981 Honda Interstate Black
1981 Honda Gl 500 Silverwing . Candy muse red
1986 Honda VT 500C red
PRESENT RIDE >1976 Honda Gl 1000 Originally red, now flat black, olive drab, primer gray.
Frenchy
Post by Frenchy »
octane wrote:BTW;
Had to try'em on:
Don't get me wrong, I'm a huge fan of white walls, but I think she looked better with the other tires...... IMHO.... :roll:
Frenchy
Oui
#252
I'm with the French one on this ... Too many stripes ... eh?
Gord :roll:
octane
#253
Post by octane »
Frenchy wrote: Don't get me wrong, I'm a huge fan of white walls, but I think she looked better with the other tires...... IMHO.... :roll:
mmmmmmmmmmmm donno.
I'm trying these as I think the Venoms
were too much of a 'StreetFighter'-look.
donno...gotta think it over
octane
#254
Post by octane »
I do like that fan set-up.
But someone had installed it too close to the belt-pulley
as you can see, there are traces of it rubbing the fan-'frame'
..had to move the radiator foreward
but the thread'ed 'pins' on the frame
that hold the radiator at the top are too short for that.
So I thread'ed them in all the way:
and the cut them shorter
and attached one of them 'sort-of-long-bolts'
which have an inside thread
..and viola: radiator moved foreward:
Facinating stuff......right ?!
Goodness! This is soooo much trouble.
I'll sell all these crappy old bikes,
leave this forum,
and buy myself a brand new Chinese
Sushizh Yuo Gong Gang Pang
Exclucive De Luxe King of The Road
125 cc Hyper Special Cruiser
...yep, that's what I'll do !
Bye bye !
octane
#255
Post by octane »
...or NOT !!!
ha har ha ho
Have a great week-end y'all!
Locked
Return to “Octane's Corner”
