'79 Wing and a Prayer
Re: '79 Wing and a Prayer
#226
action1 Very Good 👍
Cliff ;) )
#227
great
electrical gremilans are a bitch trying to figure out where the prblem is. Heck I still haven't figured the neutral light on my
ltd
NotSoLilCrippseys
#228
Post by NotSoLilCrippseys »
It's really nice when things come back together, as you all know. The electrical gremlin issue is definitely a PITA.
This afternoon, armed with my new-to-me CBR600 regulator, I got busy with some wire strippers, connectors, heat shrink, and liquid electrical tape.
Here's the story in pictures, with words interspersed.
This regulator swap is a well-known fix for the old GL1000 charging system that eliminates the OEM two-part regulator and rectifier set up. It's quite straightforward, which is convenient when it comes to electrical (or mechanical) matters.
First, I removed the battery to pull the battery tray away from the frame enough to remove the old rectifier with my 10mm and mounted the new-to-me regulator/rectifier unit. As you can see my plug is a bit ratty. I guess that's what 45 years of life next to a battery can do for you.
I ran out to Ace with my old rectifier to get matching female connectors that I could plug individually into the remaining part of the OEM plug. I split the red and green wires off the CBR600 unit each in half, to split the load and match up with what's coming off the wiring harness plug. Using heat shrink, with liquid electrical tape as a goopy sealer of sorts, I put a pretty decent seal on each wire. (Strange fact: there are 3 green wires coming into the plug, but the old rectifier has only two wires. That had me puzzled a bit, but I just left the old dead end as it was.)
Conveniently, I was able to attach each female to the corresponding male, and it tucked in nice and nice.
It's not shown in the photos, but I wrapped things up pretty well with electrical tape to help reduce the potential for water incursion. I'd say that I have it about as tight as it was with the old plug, with each connection insulated from the others.
After getting things hooked up, I snipped the 3 wires running to the regulator, taped them off nicely, and fired up the bike. My multimeter shows that I'm getting a nice 14.5v to the battery. Steady.
And my on-board voltmeter is now safely back in the normal range, way down from up in the 15/16v "white zone" of danger.
s
What a wonderful hack. I recommend it to ANYONE struggling with a failed regulator/rectifier situation on these bikes. I think I paid $35 for the CBR600 unit, including shipping. It had a couple nicks in the wires near the plugs, which perhaps made it less desirable to eBayers. But I wasn't going to use those plugs anyway.
In the Stable and Ridable
1976 GL1000 (Original Sulphur Yellow) - Needs a tag and insurance but ready to ride
1978 CB550K - son's cafe
Sold
#229
action1 excellent ! tumb2
Cliff ;) )
pidjones
#230
Post by pidjones »
I did something similar years ago, but in addition eliminated ~1 meter of unnessesary stator lead going to/from the left handlebar connector. In some countries, one phase is used to power the headlight through that connection. On the US models, there is just a jumper between the two pins. I eliminated that and connected directly the the RR connector.
NotSoLilCrippseys
#231
It's always somethin'...
Today, 5 miles into my commute home, the clutch cable broke at the lever. No spare laying around, so Ginger is out of commission for probably another week while I source a new one and await delivery.
The good news is that I was able to manage the 4 left hand stop signs and right at the light without having to cut power to the bike and actually stop. I got really lucky timing the traffic at rush hour, it would seem - including the right turn on red onto one of our semi-busy roads. The first left was dicey, as I was really dragging it to hold back until a massive dump truck came through the intersection. I almost flipped the kill switch.
When I pulled in the driveway and parked the bike, I found this.
It happens. And I wasn't 100 miles from home and on a back road run.
Even with Ginger's on again/off again temperament, I'm rapidly closing in on 4000 road miles since I backed her out of the shed. That's not bad. I'm getting darned near the break-in point for a GL1000, which I understand to be roughly 50,000 miles. At that point, I think I'll be able to stop nursing her and push her a bit. :)
Sold
#232
about 10 years ago I got back from a 2000 mile trip, the next day I went out to start the bike and pulled the lever and had that happen. Thankfully it was in my garage, not a 1000 miles from home
LLRelease
#233
Post by LLRelease »
I spent hours reading through the entire thread, with the last post being 1 year ago. Would love to have an update on Ginger? I am a couple months into my own 79 restoration project.
'79 GL1000 GoldWing (work in progress)
'82 GL500 SilverWing
NotSoLilCrippseys
#234
LLRelease wrote: Fri Aug 30, 2024 2:31 pm I spent hours reading through the entire thread, with the last post being 1 year ago. Would love to have an update on Ginger? I am a couple months into my own 79 restoration project.
LLRelease: I'm honored that you found my build worth your time! Almost everything I know about the old Wings I learned from this forum. I can't seem to find your build thread for your bike. Please start one if it's not already started.
I've been delinquent on NGWClub this summer for reasons that should not be treated as excuses. I have been busy:
  • I put a really sweet winter/spring 79 GL1000 (full Vetter kit) project in beautiful shape back on the road. Then I sold it.
  • I brought a barn find one-owner 83 CB550SC Nighthawk back from the grave in June. Fun, fast ride that really looks good. I'll sell her soon enough.
  • And in July, I took a semi-stripped for parts 86 VFR700, sourced bits from Great Britain, Florida, and Texas, and turned her into a super fun bike. I am having too much fun riding that bike - to the point of asking for trouble with local LEOs.
  • I installed 60' of stockade fence, which required me to also unstack and restack 4 cords of firewood.
  • And then there was my actual job. Oh, that.
About Ginger, she's rockin' it. I absolutely LOVE THAT BIKE! Truly.
The color pops. She presents as a mean machine, even sitting still in the parking lot. People comment all the time and want to know what I'm riding. Folks on this forum know what I mean - and you will too, soon enough.
Last summer, one guy asked, "Did you put a Subaru flat four into a motorcycle?" I laughed. They struggle to believe me when I tell them it's a GoldWing. A Wing is supposed to be something else entirely. And it's a '79, so that's a whole other conversation starter. Kids are always drawn to the toy dinosaur head mounted to the clutch lever, which I enjoy.
I'm now about 150 shy of 50,000 miles, which means I'm oh-so-close to putting 5k on her since I saved her from becoming scrap metal.
I did have really frustrating fuel and spark delivery challenges over much of '24 that kept me from rolling on the miles. But those are now sorted, and she's loading them up again. She'll top 50k in the next week - or two. If I recall correctly, someone on the forum indicated that she needed to have 50k before she was broken in enough for highway use.
Here's an early summer photo of Ginger next to that '79 build. (I documented the build of the bike in the background on a different thread.)
I recently swapped out the Bridgestone Battleax rear for another tire. I loved the tire, but the Bridgestone didn't even get me 5k, which was disappointing. Maybe I ride too hard? I opted or a Tourmaster, figuring that if I'm going to get 4-5k from a rear I might as well not spend close to $200 for it.
I might try to source a Lester rear, which I think could enable me to run a Michelin Commander II or III. The Michelin's are spendy, but I've had good, long wear experience with them on my GLs. (My son's GL - a bike we dubbed "Blue Phoenix" when we built it in '21 - has 12k miles and still has what might be 4-5k left on the tread.) The Commanders have a sporty look, and I've found them reliable in our conditions in Maine - winters included.
With my '83 front end on Ginger, I could swap on an alloy 83 front wheel (black/silver accents) that would look ok with a Lester rear. Right now, I have a Comstar from an '82 up front and the original silver Comstar rear. Not the match I'd prefer.
The Lester is not as tall as the '79 Comstar, which would affect fuel economy at speed. But I believe I could play a bit with tire size to make up some of the difference. Also, Ginger isn't a superslab tourer; she's really my fun back road twisties bike and commuter.
My left fork seal is blown, so that needs to be done. And I still have a pesky oil seep from the water pump weep hole that manifests only when she's on the center stand. I'm not all that concerned about it. When I do the fork seal, I'll probably install the Progressive springs I have and stiffen up the front a bit.
Good luck with your build!
Sold
GalDemSuga
#235
Post by GalDemSuga »
This turned out awesome and that seat setup is nice.
I Love My Old Japanese Bikes!! :mrgreen:
Valerie -78 GL1000 (current project)
Dianne -78 XS1100 (next project)
Beauty -82 GS1100G (Complete)
Dawn -83 CB1000C (future project)
Amber -83 KZ1100 LTD (future project)
Rachel -98 R1 (complete and in Germany, where I ride her went visiting my best mate)
