All around the Pacific northwest!
- mr west
Re: All around the Pacific northwest!
May 24:th
After a somewhat heavy breakfast at Union Creek, we head up to the portion of Crater Lake that is open. Its been snowing so much that its only a fraction of the whole loop around the lake they have managed to plow. But it was totally worth it!
After hanging around and enjoying the view a while, we decide to go south and hopefully have someone on the way look at the bike.
After about 20 miles we stop for gas, and could then verify that in the last 260 miles the coolant reservoir has gone from full to empty, meaning we most likely have a head gasket problem.... in Medford we call around to mechanics, all who seem busy, before stepping in to Honda retail and repair asking for help. The head mechanic was sincerely sorry they dont work on or has parts for older bikes, but he was extremely helpful in trying to find someone willing to do it, or trying to find any other solution. Maybe after seeing our two sitars and remembering the days of his youth, when he saw Ravi Shankar play, he tried even harder.
Still, to have someone work on it would cost at least 500 dollars, and take days we dont have.
So compared to that it seems better just to try to make it back, fix the bike myself before my flight home, and then see San Francisco and Redwood another time.
I would like to have a gasket kit waiting in LA when we get back. Which one should I order? Does it need to be Honda or what do you guys recommend?
1976 GL1000
1979 GL1000 Vetter
1979 GL1000 Vetter
- Sagebrush
For head gaskets Honda is best although others have had good results with Athena & Vesrah. Along with the head gaskets you will need gaskets for the coolant tubes where they meet the heads as well as new o-rings for the coolant tubes and for the carb intakes where they meet the heads and exhaust gaskets and a new o-ring for the oil nozzle located inside the head. All of that comes in the Athena and Vesrah kits.
I've never done a GL1000 head only gl1100s. There may be a gasket or o-ring needed for the left head where the cam drives the points as well. And while your in that deep you may as well replace the cam seals.
Some folks will buy the Vesrah or Athena kit and supplement it with the OEM head gaskets.
- Brant
- Board of Directors
CharlieP is in Bend OR, thats close to Crater Lake, kinda. RebelRouser is in the Dalles, OR. Either one of them guys would probably help ya if they could.
- Brant
Thats not much help, just looked at a map. Sorry.
The stp sealant is a good idea. It won't hurt the cooling system. A head gasket change takes about two hours, using a standard socket set and a torque wrench. Honda head gasket recommended. Western Honda online can get them to you at best price
Sorry I did not get back to your text. I have had good luck with Bar's leak stop leak. This stuff wont clog your radiator like other sealants will. Part #1194 available at Napa and most other part stores.
Those pics are great, makes me jealous that I'm not riding with you guys.
- mr west
Thanks for all the input! Exactly what I wanted to know. This forum is really great! Im leaning to buying a gasket kit like Athena and the head gaskets themselves from Honda.
I think I might try that Bar's for now if it wont hurt... thanks DUGG! Im sure we'll ride again some day!
1976 GL1000
1979 GL1000 Vetter
1979 GL1000 Vetter
- mr west
Should I order new head bolts too, or reuse..?
1976 GL1000
1979 GL1000 Vetter
1979 GL1000 Vetter
Yea thanks to everyone for all of your help!
Even though we have to skip some pretty things in California, I think Crater Lake was a good exclamation point as our final National Forest.
One more thing, add the stop leak directly into the radiator not the coolant bottle. Keep the shiny side up!
And while you've got the heads off you might as well put in those hotter cams
reuse the old. But make sure you clean the threads and lube the threads an under the washers to achieve the proper clamping pressure. Also check the Service bulletin for the u[dated torque valuesmr west wrote:Should I order new head bolts too, or reuse..?
https://www.ngwclub.com/File%20Share/10 ... 0%2314.pdf
- mr west
May 25:th
Starting the day in Redding. Trying to order top end gasket kit. Honda has discontinued making head gaskets, so I will just use all from the Vesrah kit. Finally we found a kit that is now waiting in a shop in LA.
The plan is stil l to try to make it nearest way back to LA via I5 or 99.
After filling ourselves with sandwiches, we filled the radiator with Bar's french dressing from NAPA... then we went. The freeway is super boring... but at least the coolant level stayed full. Then after some time slowly, slowly temp went up. We figured maybe some fresh water without that dressing would do a better job, so we changed it. Then perfect. For a while. Then slowly raising temperature. Now we noticed that the reservoir stayed full, but the radiator was not full, so we filled it up and went again. Perfect. For a while. Then slowly raising temperature. Just reached motel 6 when it started to be way to hot. Bike started to feel like running on three cylinders too.
Took out the suspect no 3 spark plug and found two small drops of liquid on it.
Ideas? How can the reservoir stay full when radiator is not? We are 230 miles from LA and would love to make it back!
1976 GL1000
1979 GL1000 Vetter
1979 GL1000 Vetter
I thought for sure that the Bar's leak would do the trick. The coolant is pushed to the reservoir when it gets hot and expands, it is drawn back to the radiator when it cools and contracts. If the engine is hot it won't pull from the reservoir until it cools down.
- Sagebrush
I don't remember if you changed your timing belts last year, if you haven't this is a golden opportunity to do so since you'll be removing them anyway. Rock Auto (order online) seems to have the best price. I think the part number is in the cross over parts list. If not someone will chime in with it.
A leak in the hose from the radiator to the overflow would cause it to be not drawn back in even when cold. The expansion while being heated would still push some out, but a small leak would allow it to suck air and lose its "vacuum " when cooling.
It might be worth checking that siphon hose from the reservoir to the radiator. Could save a lot of work and worrying.
