Timing belts don't like oil!
Re: Timing belts don't like oil!
sebastien wrote: Thu Jun 27, 2024 12:45 pm Hey all,
Here's a little update on where we're at.
snip-
At the moment, I'm playing around with iginition. For whatever reason, cylinders 3 and 4 haven't been firing great; I can tell from way less acceleration and their headers being far less hot than the cyl 1/2 ones.
please Share what you have been 'playing around' with, sebastien.
-original ignition coils and wires and spark plug caps?
-breaker points and condenser?
Old Fogey
Post by Old Fogey »
Don't be tempted to try stopping the oil leak by overtightening the cover bolts; they do snap or strip the threads easily.
You will be able to check the valve guides once the valves are removed. It is unlikely that they will have sustained any damage. If they are damaged, you must clean the outsides of the guides of any residue before removing them or risk damaging the head.
Don't even think about reusing the old head gasket!!
Do replace the two O rings on each oil feed restrictor.
Old Fogey
Post by Old Fogey »
Looks like I missed something. You seem to be past what I was offering advice for.
redglbx
Post by redglbx »
Fogey,,,👍👍👍
sebastien
Brass Member
Brass Member
#20
Post by sebastien »
gltriker wrote: Thu Jun 27, 2024 4:30 pm
snip-
Hi Cliff, yes, ignition is all stock; points, condenser, everything. Last night I rechecked and reset the ignition exactly as per Octane's instructions and Randakk's Split Timing technique and still got bad to no firing on cylinders 3 and 4. Front cylinders registered over 200C whereas rear two were around 30C, likely just head conduction through metal. I attached a timing light to the cyl. 1 and 2 wires and got the strobing light, whereas nothing came from attaching to wires 3 and 4. Today, I took a spare spark plug and tested for ignition on the L side. Got spark from the cyl. 2 lead but nothing from the cyl.4.
Now, I'm in the middle of removing my '77 coils and wires and placing the spare '76 ones and eager to see if that makes any difference. Will let you know.
1977 GL1000, 1981 GL500, 1984 Yamaha XS400J, 2009 DR650 (sold), 2004 Yamaha V-Star 650 (sold), 2001 Suzuki Bandit 1200 (sold), 2004 Honda CG125 (sold)
sebastien
Brass Member
Brass Member
#21
Post by sebastien »
Old Fogey wrote: Thu Jun 27, 2024 4:31 pm Don't be tempted to try stopping the oil leak by overtightening the cover bolts; they do snap or strip the threads easily.
Thanks for the advice Old Fogey. My in-laws are in Scotland and northern England right now on a bike trip. E-bike, that is! Looks like it's been pretty sunny; awesome :8)
sebastien
Brass Member
Brass Member
#22
Post by sebastien »
RSTman wrote: Thu Mar 07, 2024 7:04 pm In addition to the repairs due to failing belts the source of the oil leak needs fixing. Possibly a new crank oil seal and/or camshaft oil seals will be required. Some or all have been leaking pretty bad to contaminate the belts?
Jerry
For sure, I did change the crankshaft seal and have spare cam seals waiting for the right moment
#23
sebastien wrote: Fri Jun 28, 2024 3:26 pm
snip-
please Share what you have been 'playing around' with, Sebastien.
Sebastien, the solution may be something as simple as a loose plug-together bullet terminals connection in the primary ignition wiring circuit. I think of three. Two in the immediate vicinity of the affected ignition coil. Where's the Third? 🤔
:shock:
'How is that possible if I was successful to set the static ignition timing on both sets of breaker contacts, exactly as per Octane's instructions 🤔 and Randakk's Split Timing technique ?? '🤔
Len Cross had a quite similar situation... review Len's post #15 and his informative youtube video link
viewtopic.php?t=78720
:oldies important info from Randakk regarding condenser' case ground path resistance: :oldies
https://www.randakksblog.com/gl1000-con ... denser.pdf
and
https://www.randakksblog.com/wp-content ... denser.pdf
