Problem LTD
cfairweather
Re: Problem LTD
Post by cfairweather »
You can use any oil with the JASO specification or a 4-cycle motorcycle oil. If you select a non-motorcycle oil, look on the container for JASO.
Re: Problem LTD
Everything re: JASO oil specifications
viewtopic.php?t=77117
JASO MA = 4-stroke, wet clutch motorcycle engine
Paola Zago
Re: Problem LTD
Post by Paola Zago »
gltriker wrote: Tue Feb 13, 2024 2:33 pm Everything re: JASO oil specifications
thanks gltrike, for this oil specification table, always very interesting! I knew which oil to use in the ie GL, what amazed me, what scared me was hearing the mechanics at the Honda dealership who didn't know which oil to use!! How can you trust these mechanics??
Paola
Re: Problem LTD
It might help to remove the inspection cover behind the oil filler. Lots of places to go clack clack in there. I was wondering if the output shaft could be causing it. It would be worth a look before a full tear down.
One of my 77’s had either a week spring or the dogs were worn. On hard acceleration it would clunk very loudly.
A stethoscope on the alternator cover might help narrow the location of the noise. They’re both pull the motor jobs.
Paola Zago
Re: Problem LTD
#20
good morning everyone, I found an old mechanic who was willing to dismantle the engine of my LTD, and was asking me if it is possible to replace the complete shaft code 13410-371-000 which has the 12 rubber pads, with that of the GL 1100 which has springs, certainly more robust and long-lasting.
and if the slider with the chain tensioner of the later version can be mounted on the 1976 engine.
Thanks in advance everyone
Paola
Old Fogey
Re: Problem LTD
#21
Post by Old Fogey »
As far as I am aware, all the 1100 models still had the rubber dampers; that wasn't changed until the 1200 came in.
I don't know if the 1200 version will fit, although it wouldn't surprise me if it did.
You can fit the sprung chain tensioner from all the four cylinder models from 78, but you can't fit the slider block from the 1200 as it is too thick.
https://www.wingovations.com/fittingasprungprimarychain
Paola Zago
Re: Problem LTD
#22
Old Fogey wrote: Thu Mar 21, 2024 7:15 am As far as I am aware, all the 1100 models still had the rubber dampers; that wasn't changed until the 1200 came in.
Thank you very much for these clear clarifications and descriptions, now we know how to proceed.
Thank you with all my heart
Paola
Paola Zago
Re: Problem LTD
#23
Hello everyone, I'm still at sea with the engine of my LTD, the fault that caused the loud noise was identified in the excessive play of the shaft generator. I wanted to know if it is possible to install the one on the 1100, which I found at a good price, and if it is serviceable unlike the one on the LTD which is sealed.
thanks in advance everyone
Paola Zago
Re: Problem LTD
#24
or can the Generator Shaft of the 1200 which I saw from the part list which has springs instead of the rubber pads which are unobtainable, be installed in the LTD engine??
Thank you in advance
Paola
Re: Problem LTD
#25
What is the part number of what you need? I just threw away 2 engines but I am sure someone on here has a scrap one laying around they could pull it from.
Old Fogey
Re: Problem LTD
#26
Post by Old Fogey »
I found the rubber buffers needed to fix her problem and sent the link.
Trying to find a good used unit is a gamble; there is no way of telling what the rubbers are like without dismantling the unit.
It would be interesting and useful if someone with a stash of parts could try the 1200 unit in a 1000/1100 case. The mesh between the crank gear and the shock absorber gear might be a problem, apart from anything else.
Re: Problem LTD
#27
action1 action1 action1 action1 action1
Paola Zago
Re: Problem LTD
#28
Whiskerfish wrote: Mon Jun 24, 2024 9:09 am What is the part number of what you need? I just threw away 2 engines but I am sure someone on here has a scrap one laying around they could pull it from.
This is the complete generator shaft, I really thank you for your availability, but I would prefer to find it in Europe as from the USA the shipping costs and customs duties are a massacre. For the three oil pipes of a three-cylinder Kawasaki, paid 80 dollars, I spent 46 dollars on shipping and 61 dollars on customs duty!!!
Paola
Paola Zago
Re: Problem LTD
#29
Old Fogey wrote: Mon Jun 24, 2024 3:18 pm I found the rubber buffers needed to fix her problem and sent the link.
Hi, unfortunately I lost a few days ordering those swabs, and they were sold, I bought two used sets on ebay, one set in Germany and one set in Spain, but of 24 swabs, only three are recoverable. a disaster. John Evans wrote to me that yes, you could try a 1200 unit, but........
Paola
Old Fogey
Re: Problem LTD
#30
Post by Old Fogey »
Any Portuguese speakers here?
I just came across this. I don't know if these are NOS or if they are maybe producing them That would be VERY interesting if so!
https://produto.mercadolivre.com.br/MLB ... 71-000-_JM
