Lucien Harpress wrote: ↑Mon Aug 08, 2022 12:07 am
Honestly? Purist though I am, I say do the minimum to get it road worthy (belts, fluids, etc.), then just fire the sucker up. It may run better than you'd expect.
Thank you, I feel that makes the most sense as well. Hoping to be to that stage in about 2 weeks!
You're cooking with gas on your Goldilocks project. Nice.
Rear cover has been off for some reason. OK. She's been around a few blocks. Heads may have been replaced (or one may have?). It's been 50 years, after all. Someone liked GL1100 carbs - or had a rack available when the original one got finicky. They'll do for now - or perhaps forever. Maybe the radiator just needs a good cleaning.
I'm all for fixing what needs fixing, making her safe and roadworthy (tires, brakes, lights, etc.), and riding her. Or go for the concours restoration and get ready to hunt down some near-unobtanium.
I don't want to add stress to what right now may be an ever-growing list of known unknowns that seem to be outstripping your ability to turn them into known knowns.
To follow up on the concerns raised about that red rtv-type sealant, one option might be to pull the oil screen to see what's been caught in it over the years (right side of motor, very bottom, hiding behind the lower frame member, 2 screws).
It'll be tricky to get the screen cover off with the engine in the frame, especially with 50 year old JIS screws holding it in, and the right header needs to come off at a minimum. Consider it if you really want that peace of mind by (hopefully) confirming that no red RTV bits have been roaming around in the motor. Definitely have a look if you end up having to pull the motor for some other reason.
At the rate you're going, that bike will undoubtedly roll down the road under its own power before you know it!
In the Stable and Ridable
1978 CB550K - son's cafe
1972 CB500F - recently acquired project on tap for winter '25-6 FrankenWing - 1980 GL1100 motor in 1982 or 1983 frame (still deciding, so maybe semi-active).
NotSoLilCrippseys wrote: ↑Tue Aug 09, 2022 6:18 pm
Thanks, I am really enjoying the process! I haven't taken on a rebuild since I was in my 20's when I rebuilt an old Yamaha Seca 400 that had been wrecked by a friend.
Thanks for the tip about the oil screen, I will keep it in mind when I am stripping the bike down further this winter. For now I'd just like to ride it
FWIW - the oil screen seems like a real pain, but it took me about an hour from start to finish. Drop the right header, loosen the motor mount (I might have loosened the two closest mounts as well) and use a wedge to pull the frame out 3/8" or so (frame is flexible, you won't hurt anything), and remove the 4 screws with an impact driver. Using hex head bolts to reinstall makes the job easier in the future.
low-side wrote: ↑Thu Aug 11, 2022 5:37 am
Thanks for sharing that, I might just do it then, I'll be back on the project next weekend
For a wedge, I used a plastic wedge used for keeping your chain saw from getting stuck. Fairly non-maring.
Finally found the time to get to posting an update on my progress.
Long story short the bike still doesn’t run.
I cleaned the carbs as best I could an reassembled everything. Upon trying to fire it up a significant leak developed from the fuel tube between carbs 3 & 4.
So now it seems I am in to tearing down the carbs even further than I had already done and I’m just too busy right now to get to it.
I’m feeling like if I need to tear them down to that degree I should just get the rebuild kit from Randakk’s.
So seems my hopes of riding the bike this season are withering away since I just don’t have the time to get to it right now.
To me, if the carbs are coming off again, it's worth making sure they're cleaned and rebuilt correctly before going back on. A bike done right and ridden eventually is better than one rushed into and ridden poorly right now.
Not to mention that while there is a lot to these bikes, it definitely becomes less intimidating the more you dig into them.
Best of luck!
Nice find, I've always wanted a yellow one. And no big deal, but are those '78 pipes on it?
And a brown seat! I thought I was the only one who had a brown seat! My '75 has a brown Saddleman (or whatever it's called-it came to me that way), but I rather like the bench-style. But still...! "Go, Brown!" DSCN1885 by Dr. Frankenstein1, on Flickr
