Western Canada 77 GL1000
Re: Western Canada 77 GL1000
sebastien
Video time. This first one is on a cool morning, temp high 40s, cold start. Choke is fully out but engine doesn't rev up to 3000K and beyond, just idles low enough to not stall.
Second video is after 10-mile ride to work that same morning, about a 17-min ride. Temp is normal but idle still a bit low and bike starts idling erratically, so I have to give her a bit of throttle to get her normal again.
Last video is coming back home that day. Outside temp in low 70s, idle is now good but obviously quite high. In your experience, does idle speed vary on gas tank volume? Wouldn't there be more fuel pressure when tank is full or does the pump typically work well enough to deliver fuel at same rate no matter what the tank volume?
I know I need to clean and likely overhaul the carbs but do you think ignition sounds like it's well-set? Looking forward to your comments, hope the weekend offers you good riding,
1977 GL1000, 1981 GL500, 1984 Yamaha XS400J, 2009 DR650 (sold), 2004 Yamaha V-Star 650 (sold), 2001 Suzuki Bandit 1200 (sold), 2004 Honda CG125 (sold)
It is not running on all 4 jugs. You can use a IR temp reader or a spray bottle of water on the headers to see which cylinders are hot and which are not.
