Bad u joint on my GL1000
pidjones
Re: Bad u joint on my GL1000
Post by pidjones »
5speed wrote: Sun Dec 27, 2020 4:47 pm
pidjones wrote: Sun Dec 27, 2020 4:40 pm Another option to consider for locating a new joint would be some kind of epoxy. Some cars and trucks use a thermoplastic blob to hold theirs in place, but it can be melted out and there is a snap ring groove for rebuilds. Don't know which I would trust more, though - snap ring or epoxy?
I changed the u joints in my 86 IROC 2 years ago and they were the original ones held in with the plastic retainers..
I wonder if you would throw the drive shaft out of balance if the globs of epoxy were different weights..
Epoxy is so light that I doubt you would have that much differential weight.
Shadowjack
Post by Shadowjack »
Here's the difference between a 1000 shaft and an 1100 shaft, which I mentioned above. The 1100 front yoke was too beefy to get the old crosses out by pressing them inward, as you do, so I had to saw it off. The cross replacements were the same size, so I could put an 1100 swingarm onto a 1000 frame.
I have several old driveshafts, mostly 1000's, that need U joints. I would be interested in the part number, and supplier of the
u joint you used. My supply of good 100 shafts is down to one :(
5speed
Post by 5speed »
CYBORG wrote: Mon Dec 28, 2020 9:42 am I have several old driveshafts, mostly 1000's, that need U joints. I would be interested in the part number, and supplier of the
https://www.drivetrainamerica.com/neapc ... r-u-joint/
any heavy equipment parts place should have it..
#20
thanks. Ordered one just now. Will see how it works out before ordering more
5speed
#21
Post by 5speed »
CYBORG wrote: Mon Dec 28, 2020 10:30 am thanks. Ordered one just now. Will see how it works out before ordering more
does this mean we can expect a "how to" tutorial by cyborg? anim-cheers1
#22
5speed wrote: Mon Dec 28, 2020 10:37 am
could be :lol: Actually just ordered one to test the water. Just came from Napa on another mater, and asked them to check that number for a cross ref. they could not find one. Interesting.
5speed
#23
Post by 5speed »
CYBORG wrote: Mon Dec 28, 2020 1:15 pm
I tried to cross reference it on rock auto and couldn't either. Hopefully it isn't a proprietary u joint exclusive to freight shakers.
ETA..found this cross reference for a spicer..was all excited until I saw the made in china part. :(
https://dcjperformance.com/products/spicer_5-3256x
#24
5speed wrote: Mon Dec 28, 2020 1:31 pm
Doesn't really matter. Was only $30 or so shipped to my door. The BMW one, which was rumored to be the one Honda used for the Goldwing, last I checked, was $60.
MikeNTexas
#25
Post by MikeNTexas »
Moog #405 is the same part. I have one coming through my local parts guy. $19 and change.
1975 GL1000 Restored (sold)
1983 GL1100 Custom (sold)
5speed
#26
Post by 5speed »
specs for the Moog one..which rock auto has. lol
Bearing Cap Axis 1 Diameter 0.750 In.
Bearing Cap Axis 2 Diameter 0.750 In.
Bearing Diameter A 0.750 In.
Bearing Diameter B 0.750 In.
OE Series 0400SG
Length A 1.906 in.
Length Axis 1 1.906 in.
Length Axis 2 1.906 in.
Length B 1.906 in.
Bearing Cap Axis 1 Diameter 19.05 mm
Bearing Cap Axis 2 Diameter 19.05 mm
Bearing Diameter A 19.05 mm
Bearing Diameter B 19.05 mm
Bearing Cap Type 4 Round Plain Bearings
U-Joint Identification 4 Round Plain Bearings
Length A 48.41 mm
Length Axis 1 48.41 mm
Length Axis 2 48.41 mm
Length B 48.41 mm
Greasable No
Lubricateable No
Length Measurement A Outside of Bearing To Outside of Bearing
Length Measurement B Outside of Bearing To Outside of Bearing
Bearing Type A Round Plain
Bearing Type B Round Plain
#27
MikeNTexas wrote: Mon Dec 28, 2020 1:40 pm Moog #405 is the same part. I have one coming through my local parts guy. $19 and change.
I figured there had to be more then one . Let us know how it works out
digger
#28
Post by digger »
I wonder if Loctite 648 retaining compound would work better than epoxy. https://www.henkel-adhesives.com/us/en/ ... e_648.html
5speed
#29
Post by 5speed »
I added the part #'s to the cross reference thread so roady can edit his original post.
MikeNTexas
#30
I got the Moog 405 u joint today and installed it. It appears to be a little wider than the stock U joint and the cups don’t slide into the yokes quite as far as the factory joint. I saw no other option other than to stake it on place with a center punch much like the factory did. Between the interference fit and staking it I feel comfortable that it will stay together.
