Fan thermo switch; is this right? (cheap FIX?)
taunusrainer
Post by taunusrainer »
I am very sure Your local Ford or GM dealer can match it up if You show him the fan switch, 8$ is reasonable, 100$ is crazy.
CU
Ray
jacknj
Post by jacknj »
Roady wrote:Okay, I finally got it.
The replacement Honda part and even the after-market ones are expensive ($45 to $100!). The one in my Ford does the same job for $8.
Roady - for those of us still looking, what year/model ford? for 8$ i'd love to replace mine.
thanks man!
-j
Ooops. that was misleading.
I meant that the one for my Ford is $8. Not that it's the one that fits in the GL.
I'm haunting the local parts stores now to find one that might work. Someone mentioned that the one from an Escort 1.6l Injected would work. But the one at AutoZone does not have a long sensor like the GL one does.
I'm still looking, anyone else have any idea which one?
05c50
Post by 05c50 »
I stumbled across a listing for a universal thermstatic switch in the JC Whitney catalog. It says that it's adjustable from 170-240 degrees. I think it's about $20. Might be something to look at.
....Paul
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
taunusrainer
#20
It has to be the right thread and the right switch temp, nothing else matters.
Guess it would be quite a business to offer machined adaptors for the 8$ Ford switches...
JC Whitney
has this one
http://www.jcwhitney.com/autoparts/Sear ... rchbtn.y=0
but it won't fit into the thermostat housing
CU
Ray
alan hawke
My Album: http://www.ngwclub.com/gallery/v/wingmans//alanhawke
#21
Post by alan hawke »
Thermo switch to suit a 1989- 2001 suzuki swift..... or..... 1996-2004 suzuki Alto will fit, same heat range ,same thread pitch . i have been using one in my bike for last twelve months or so works fine.
Alan
1976 GL1000
2000 ZX6R KAWASAKI
2009 vn1700 kawasaki classic
tyring59
reading up on them
#22
Post by tyring59 »
Honda seem to use the same switch on more then the goldwing. Once I look it up in a online parts cat and it was the same number from 75 to 87 goldwings. I forget which other Honda's used it.
Anyway great info from the car guys because I ve been asking for years and no one seem to know if any car ones would work.
Went and bought a used one for 25 bucks.
octane
Re: reading up on them
#23
Post by octane »
tyring59 wrote:Honda seem to use the same switch on more then the goldwing. Once I look it up in a online parts cat and it was the same number from 75 to 87 goldwings. I forget which other Honda's used it. .
The following Hondas use the same switch:
Da' Supercharged Bulldog
Antoine de Saint-Exupery
#24
I bet honda charges the same thing regardless of the model.... but it isn't only mother-honda that scr3ews you parts... I needed a thermostat for our saturn car once.... nobody, except saturn, made that kind of thermostat $$$$$
It took a while but I finally got the bike running again and can finish this thread. I don't think that I'd do it again like this but it works and I'm pleased.
I did some research and got indications that a fan switch from a Geo Metro, 3-cylinder (1.0L) matched the threads and temp rating. I couldn't get one locally so I found the part on RockAuto.com for $8.23 + $6.29 shipping. Click the Part Number Search tab and put in the mfg. and number.
Details:
1994 Geo Metro 1.0L 993cc 61cid L3 TBI
Radiator Fan Temperature Switch. Mfg: Beck/Arnley, Part# 2011614.
(I see they're offering the closeout switches even cheaper now.)
The Geo switch does not have the long probe that goes into the thermo housing. It also has a different connector. So I fashioned a pigtail from 4 inches of wire and bullet connectors. Then I shrink-wrapped it all and stole a black rubber foot off grandpa's cane and here's the finished product.
[attachment=0]geothermo.jpg[/attachment]
I couldn't find any specs on what wire is which so I just chose one side to be green and one side to be white/red (I think those were the colors). I figured if it didn't work I could switch them.
Amazingly, it works! Fan comes on when it should and all is well.
UPDATE: Though this switch worked I ended up replacing it with an OEM switch (about $80) when I later replaced the water pump and head gaskets.
WingerDave
My Album: http://www.ngwclub.com/gallery/v/wingmans/album225/
#26
Post by WingerDave »
Just a little bit of info..............
The fan switch off of a 1980 Honda Civic is the same range and, basically, exactly the same unit BUT..... a smaller thread (2mm smaller). It's also about a 5th of the price. One way of commanding a high price.
The American Escort was built on a Mazda 3 chassis (as was the Australian Mercury and a few other cars of that period) Talk about Globalization !!!!.
There are even Nissan Bluebirds from the late 80's with BMW front suspension....... problems with supply between Japan and the assembly plant in England.
Dave.
If it ain't broke, don't fix it.
'80-'81 GL 1100 Hybrid Vetter Interstate 90K km
1989 GL1500 58K mls
Previous bikes
1973 Suzuki GT 500
1975 BMW R60/6
1982 Suzuki GS 550
1980 GL1100 (frame went to current bike, rest parted out)
1983 GL1100 Interstate
If I could find one with the same connector that would solve the problem. But then it'd have to have the same size thread, eh?
Wouldn't you think it would be easier if more mfg's used the same parts to do the same jobs.
Sheesh! Guess they like to make more money, eh?
#28
or put things like light switches and windsheild wiper switches in the sma eplace.... naw, would be to easy
RB
#29
Post by RB »
Not to high jack the thread but..a PO permanently wired the fan tot eh ignition somehow so it comes on where I turn the key on to start the bike. I'd like to put a switch in the wire so I can at least turn it off when starting the bike. What I need to know is where the fan wires hit someplace easy to get to on the frame so I can wire in a switch and place it in a handy location.
I figure I can cut in anyplace to do this..but having trouble tracing/finding the fan wires..I can see them coming out of the thermo unit but they disappear behind that metal sheet behind the radiator..when do they come out????
This is on an 80 1100
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her :(((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
AttilaB
#30
Post by AttilaB »
I as well did the RockAuto part #2011614. After a little soldering & crimping and such, took her out for a spin and lo and behold - the fan turns on when she's supposed to!!!
'76 GL1000
'75 GL1000 Dressed (not for long!)
