Track T 2411 wrote:I agree that the compression numbers are low. Anything under 90 psi is most certainly going to affect performance. I'm also curious why you removed the resistors from the plug caps. Not that I'm much of an ignition master, but I've read that the resistor helps 'shape' the strength and duration of the spark.
Several years ago, Whiskerfish had mentioned this phenomena, but the results I found from a "search" for the details of spark shaping lead to something way over my head about a subject involving 'plasma'.
My aged, yet still inquiring mind, needs to know less about plasma and more, beyond addressing Radio Frequency Interference, about supplemental resistance enhancement in a Kettering ignition system. ( I guess that's what I'm needing to understand?
Can you please direct me how and where you found this info., Track T? Thanks!
