CX500 / Trident Police Trike Rebuild
- scootsx2
Re: CX500 / Trident Police Trike Rebuild
I have been using NGK plugs for years. I typically buy them at NAPA. The plug in question is from a box of 10 that I purchased 2 - 3 years ago and it appears to comply with the "genuine" characteristics on the NGK web page. That said, I just noticed the box has cyrillic printing on it. I never noticed that before. It may be due to worldwide distribution of the product but then again it may indeed be a bootleg product.
1975 GL1000 Sidecar Outfit
2001 GL1800 MotorTrike
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
- 05c50
A few years ago when the fake plugs hit the market, one way to tell if they were genuine was that the cyrillic printing appeared on the box. That says "made in Japan" in Russian and it indeed is supposed to be there. I'd say that you have the genuine (albeit a bad) NGK plug.
.......Paul
.......Paul
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
- Toehead
looking great. Keep it up!
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
1980 CB750C (sold)
I'm enjoying this uild, you are doing a bang up job. Any idea where this bike was used?
You mention not knowing what the second solenoid is for. I see a toothed ring gear on the front yoke of the rearend. Can't see it but is there a starter on there? If so the solenoid is probably for that. The starter on the ring gear would be for reverse. I'm just sort of guessing here though.
- scootsx2
St. Louis Police Dept.sunnbobb wrote:I'm enjoying this uild, you are doing a bang up job. Any idea where this bike was used?
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
- scootsx2
In tracing down the wiring, it appears to feed some of the police conversion stuff... switchable power feed to lights, siren, etc. The conversion wiring has proven to be well isolated from the basic CX500 wiring which has made it easy to track things down and get stuff working.robin1731 wrote:You mention not knowing what the second solenoid is for. I see a toothed ring gear on the front yoke of the rearend. Can't see it but is there a starter on there? If so the solenoid is probably for that. The starter on the ring gear would be for reverse. I'm just sort of guessing here though..
By the way, that 2nd solenoid had an internal short and smoked as soon as I connected the battery. A continuous-duty replacement solenoid is on order from an Ebay supplier. I had noticed about 56-ohms resistance between the +12V battery lead and ground with the ignition off before connecting the battery and that was a red flag. I expected an open circuit. After disconnecting the fried solenoid I had the expected open circuit with the ignition off.
Regarding the ring gear, it's probably part of a reverse mechanism that isn't present on this trike. I plan to try implementing an electric reverse but that will be at some time in the future. Right now I just want to get this machine back on the road.
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
Was the second solenoid used to power a starter motor for reverse perhaps?
- hacksaw1945
I sure am enjoying your post, and the nice work and trouble shooting your doing. Thank You
1977 Honda GL 1000, 1982 Honda GL 1100I went naked, 1976 Honda LTD rough long range project, 1945 Indian Chief, 1947 Indian Chief, 1948 Indian Chief, 1958 Cushman Highlander, 1959 Cushman 3 wheel Mailister, 1966 Triumph TR6,
Read a couple posts up from your original.sunnbobb wrote:Was the second solenoid used to power a starter motor for reverse perhaps?
- scootsx2
I spent the last two evenings removing the coolant overflow reservoir. The plastic was severely deteriorated from engine heat - it's tightly sandwiched between the engine and the frame. Some of it crumbled when touched and the rest took a bit of convincing to remove. Turns out that the extra coolant reservoir that I found in the trike's rear box isn't correct and will not fit in the available space. I ordered a small "universal" coolant reservoir on Ebay and will mount it in a different location. There's lots of room on this thing so it should be fairly easy to do. Based on its dimensions, it might just fit in the donor bike's original battery location on the left side.
Next step is to install the carbs and try to get the engine to fire up... hopefully within the next couple of days.
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
- scootsx2
This evening I installed the rebuilt carbs. The original intake manifolds (carb insulators) were in lousy shape. One was blistered from heat and the other was cracked all the way through the rubber. I obtained aftermarket replacements from David Silver Spares and they fit perfectly. I used a film of silicone dielectric grease to lube the rubber pieces a bit during assembly.
Tomorrow I will pick up some fuel tubing and a filter, hook up an auxiliary fuel tank and see if I can get this beast to fire up.
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
Fingers crossed!
- scootsx2
IT'S ALIVE!!!
I connected an auxiliary fuel tank and the bike fired right up, even without the choke. Granted it hadn't been run in about 10 years (the plates expired in 2006) and it was cold and it stalled right away. A little choke and she fired up again and stayed running, warmed up nicely, idled smoothly at about 900 RPM once warmed up. The oil pressure light goes off right after startup.
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
- Toehead
Sounds good!
Have you checked/adjusted the cam chain tensioner yet?
1980 CB750C (sold)
1980 CB750C (sold)
