1978 GL1000 Low Buck Project
Goboy
My Album: viewtopic.php?f=30&t=60678
Re: 1978 GL1000 Low Buck Project
Post by Goboy »
Install belts, insuring the timing marks are lined up when you do. Its easier to work on one belt and tensioner pulley at a time, less chance of messing up the timing. Leave the tensioner pulley bolt a little loose and manually turn the engine "several rotations" and then tighten the tensioner pulley bolts. The belt tension should now be fairly tight.
I had my rad off so I installed a temporary hose so I could run the bike. You have to readjust the tensioner pulley tension with the engine at operating temp. Watch the temp gauge and feel the hose as you bring the engine to operating temp.
Check the belt tension now, then loosen the tensioner pulley bolts and turn the engine and re-tighten the bolts. Never force or push the belts, let the springs do the tensioning. This may be a good reason to change your springs once in a while.
You're too small to ride a hog Billy!
Mike
1978 GL1000
Previous bikes: 05 Yamaha FJR 1300, 79 Suzuki GS 1000, 75 Yamaha XS 650, 73 Kawasaki S2 350
Goboy
Post by Goboy »
Now after re-checking the timing marks you can install the rad. but I have a new problem. When I had the engine warming up I noticed that the right cam sprocket was wobbling. A PO had dropped the bike as the right crash bar was ground flat on the bottom. Something must be bent, removed the sprocket,checked, reinstalled, same. The rear cover plate was also bent and had cracks.
So picked up some used parts. Cleaned painted the rear cover plate, installed the new sprocket and belt, manually turned the engine and tightened the tensioner pulley bolts, checked the timing marks. All Ok, cranked it over, no wobble!! dancr
Mike
1978 GL1000
Goboy
Post by Goboy »
Easy fix for rotted rubber bushing (or washers?) for electric radiator fan mount, use pieces of vacuum hose.
Mike
1978 GL1000
Patriccio
Post by Patriccio »
That's it! Nothin' fer a year?! I think you might be in violation of some by-law in another galaxy. Nice little triptych thing w/ the pics.
Goboy
#20
Post by Goboy »
I'm definitely in violation (I maybe banished from this site if I don't pull up my socks :shock: ). I've done a little and adding pic's SLOWLY!! I'm going to rename it the Slow buck project! I just have too many things on my too do list. :roll:
Mike
1978 GL1000
heraldhamster
#21
Post by heraldhamster »
Goboy wrote:...I just have too many things on my too do list. :roll:
we should start a club. I haven't built one in over 4 or 5 years (and I have 3 waiting to get built)... but I have a runner, almost two (but no time to track the problem on the 2nd).
likin' your progress. especially those replacement bushings. good on ya, man.
H2G2=42
#22
Duke182, that was your queue.
Goboy
#23
Post by Goboy »
Since Patricco been prodding me for something, anything, I submit "THE PAINTING OF THE RADIATOR". It took 3 long nights to sand all the nooks and crannies, wiped it down twice with wax and grease remover. Then sprayed it with black caliper paint and baked it for 30 min. @ 250 (or until lightly browned). Then threw in a frozen pizza to get rid of the smell. I still can't believe the wife didn't put up a fuss.
Mike
1978 GL1000
Patriccio
#24
Post by Patriccio »
That turned out quite nicely. I suggest Radiator of the Month.
