Crazy idea...
Re: Crazy idea...
Anyone know if C5 is able to provide the signal? Seems like more than 36 tooth wheel, but maybe with microsquirt still works.
Re: Crazy idea...
You'd have to ask Paul.
- roncar
Re: Crazy idea...
Tach signal? Sure does. Whether it works with the microsquirt or not,ericheath wrote:Anyone know if C5 is able to provide the signal?
Re: Crazy idea...
This is my fifth season with my 75. Starts fine, runs fine. My carb were rebuilt by a Honda dealer in 1997-99 from what I can tell. So that's 16 years after carb rebuild. I keep waiting for
run ability problems, but knock on wood. I try to ride every week in summer and I've gone
as far as two months in winter without starting. On stablized, non ethanol fuel.
So don't be afraid of stock carbs, imho.
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
Re: Crazy idea...
I LOVE stock carbs!!!!!!
- irishcarbomb
Re: Crazy idea...
I believe with the c5 you would still get the signal off the coils
Re: Crazy idea...
Yeah I'll probably go with a rebuild of the stockers for this year. But next year... I've got this lonely CT12 turbo sitting on the bench... And it's far too small for any of my cars, but would work perfectly on something 1000cc and fuel injected...
Re: Crazy idea...
I think it helps to have an idea of how well the stock bike runs with stock carbs before converting to efi. I went through the process of rebuilding the carbs, which was no easy task for me at the time since I probably hadn't touched a carb in 10 years. The internal passages are very small compared to, say a Holly 4 barrel, and harder to get clean.
Roncar's diagram of the c5 (earlier in this thread) shows a tach signal output with 1 pulse per crank revolution. Microsquirt can use that kind of tach signal very well. My first microsquirt system used the same signal, although it came from a modified stock ignition.
Good luck with your project!
- Toehead
Re: Crazy idea...
Also, don't be afraid of EFI.... mine is a simpler system, being TBI, but I went from nothing to a running with microsquirt in 2 weeks.
The stock carbs are great for performance, but the EFI conversion scratches the modification itch pretty nicely
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
1980 CB750C (sold)
Re: Crazy idea...
Toehead, what'd you get the throttle body from/what is it built for? And you're running megasquirt? Didn't know MS would run a tbi setup, I've only read about them being used on 4 cyl TPI and ITB setups before now.
- Toehead
Re: Crazy idea...
It's from a Geo metro. I'm using microsquirt to control it. The megasquirt is very adaptable.. It can run almost any configuration you can think of.
My build thread was posted a few days ago.
1980 CB750C (sold)
1980 CB750C (sold)
Re: Crazy idea...
Oh I've owned and worked on a metro. That's probably why you're lacking a little performance compared to the stock carbs. The metro tb is tiny! I'd think you'd have better performance matching hp rather than displacement in this case. I mean the metro only makes like 53hp, vs the bikes 90? I'd think you'd be better served by swapping tb with some donor that makes closer to 90-100 hp, even if the displacement is different.
Re: Crazy idea...
1976 GL1000 was factory rated at 82HP. And we all know the factories were a bit optimistic on HP numbers back in the day.
Re: Crazy idea...
I agree......but some were driven by insurance companies (999cc)
- Oldboy
Re: Crazy idea...
I'm with Rat....unless of course you like to tinker, then I'm with you!
Cheers...
Just Wing-it
Just Wing-it
