GL1000 tach cable oil gasket
SnoBrdr
Re: GL1000 tach cable oil gasket
Post by SnoBrdr »
CYBORG wrote:Yes
Do you have to pull off both the pump AND the fuel pump cover or just the pump?
78 GL1000 Original Owner 131k
NCScooter
My Album: http://ngwclub.com/gallery3/index.php/w ... ter?page=1
Post by NCScooter »
SnoBrdr wrote:
CYBORG wrote:Yes
Hain't done it yet, but the cable is held in there by the inboard bolt that holds the pump assembly to the head. The pump and tach are driven by the Right cam shaft. It will be those 2 bolts that I remove. The photos kind of show this. I have an electric pump, but it is that bottom elbow that needs to be accessed. GURUS-correct me if I'm wrong.
I need to remember to keep my expectations tiny so I don't end up so whiny.
1976 CB400f
Image 1977 GL1000-The Breeze
I'm so special, my short bus only has two wheels!
I would pull the cover, just to make sure ,if you want to pull the gear. But you do not need to remove anything but the top bolt,and the csble. You can then pick the old seal out, and install the new one, and replace the seal. A half hour job, if you stop for a beer half way through
The first half takes 5 minutes ..... the last half a little longer ......
Gord anim-cheers1 anim-cheers1
NCScooter
#20
Post by NCScooter »
Thanks for the info. My dealer said they may come tomorrow. It's the middle half that slows me down.
1976 CB400f
Wingerinsandiego
#21
Post by Wingerinsandiego »
I was surfing Ebay a while back and saw what was called a "tach housing" designed to fit on the front wheel. Wish I had a pic! Anyway was this mislabeled tach instead of speedo housing. If it is for the tach how does it work, and why have 2 spots for the cable?
1976 LTD
1985 LTD (SOLD) To support my naked obsession!!
I don't want a nickel, just want to ride my motorcycle!
#22
cannot be a tach housing if it is one the front wheel
Wingerinsandiego
#23
I try to get a pic and post it.
1976 LTD
SnoBrdr
#24
Post by SnoBrdr »
rcmatt007 wrote:cannot be a tach housing if it is one the front wheel
That's why it was on EBay, it was a very, very rare item.
Guy probably wanted a fortune for it too. :mrgreen:
Wingerinsandiego
#25
$18 about the same as the housing that bolts up to the fuel pump. No luck downloading a pic or information. Ebay has it listed as the "original front wheel tachometer drive for a 76 Goldwing. Can it be used in place of and is there any advantage to using it? How would it be installed. I don't know, but it is intriging. Never seen one before.
1976 LTD
#26
This what you are talking about? http://www.ebay.com/itm/1976-76-HONDA-G ... cb&vxp=mtr
That is the speedometer drive.
Wingerinsandiego
#27
Thanks, I guess it was a typo!
1976 LTD
#28
Wingerinsandiego wrote:Thanks, I guess it was a typo!
Or a seller who has no clue. ;)
#29
Bingo! An unbelievable amount of mis-labeled Goldwing parts on eBay now-a-days.
NCScooter
#30
Post by NCScooter »
Wingerinsandiego wrote:I was surfing Ebay a while back and saw what was called a "tach housing" designed to fit on the front wheel. Wish I had a pic! Anyway was this mislabeled tach instead of speedo housing. If it is for the tach how does it work, and why have 2 spots for the cable?
I know this is late to the game. I was out of town, but is it for the left front wheel or the right front wheel? lolol
1976 CB400f
