Brake Caliper Piston Removal Made Simple
tomk1960
Re: Brake Caliper Piston Removal Made Simple
Post by tomk1960 »
ericheath wrote:Nice vid. I look forward to the others. Growing up in Cow Hampshire and going to college in Mass, the accent was like music to my eahs.
And here I thought I had a neutral accent...I guess some of the "Wistah" in me came through, eh? :oops:
1986 VFR750F Interceptor
1978 Honda GL1000
Topwingnut
Post by Topwingnut »
Great video and excellent quality ... Look forward to many more ...
1980 GL1100 Interstate naked
1982 GL1100 Interstate Bobber ( in progress )
1983 GL1100 Interstate Bagger
abert51
Post by abert51 »
very nice contribution to the site Tom (and son in law). Thank you.
78 Nekid
73 Shovel
73 Tiger
71 Commando
67 305
70 450 Scram
2002 Spirit 750
79 CB 750 Anniversary
mbs.
abert51
Post by abert51 »
'wistah' as in Worcester MA. I'm in Sutton. golly.
78 Nekid
73 Shovel
73 Tiger
71 Commando
67 305
70 450 Scram
2002 Spirit 750
mbs.
tomk1960
#20
Post by tomk1960 »
abert51 wrote:'wistah' as in Worcester MA. I'm in Sutton. golly.
Just 20 minutes down the road from me...we have enough local NGW members (at least 3) to start a Massachusetts chapter!
1978 Honda GL1000
Toehead
#21
Post by Toehead »
Id say at least 5 :)
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
bonestock3
#22
Post by bonestock3 »
So I'm very new to this, I've watched this video several times and I get the idea, but I'm trying to figure how to get to the bleeding aspect of things from a stock standpoint. I figure Caliper off, brake pads out, but then what? Does it bleed automatically? Should something specific be removed to allow the flow of brake fluid? What? I need to get into my right caliper but plan on going through the whole braking system for a thorough cleaning and inspection. Where should I start? I've watched all your YouTube videos (I'm a fan) but still not sure where to start. Thanks in advanced.
Bonestock©
1979 GL1000 - Avomew
#23
For the most part you need the system complete and installed. Otherwise the pistons would just be pushed out of the calipers
Try some reading here http://en.wikipedia.org/wiki/Brake_bleeding
Youngster
Zinc Member
Zinc Member
#24
Post by Youngster »
This video is great - very helpful. Is there any reason why one couldn't just pull the calipers off the rotors and leave them connected to the master cylinder to complete this function? I could imagine that the mess of brake fluid so close to the bike would be an issue, but otherwise it seems possible. Also, do you have any tricks for getting new Pistons into the calipers after rebuild? Thanks!
Toehead
#25
Post by Toehead »
If you get all the scale out of the seal grooves (I use a brass wire brush wheel on a dremel), the piston should go in with hand pressure. Lube the seal with some clean brake fluid first.
If you have to force it with a press or clamp, something isn't right.
1980 CB750C (sold)
5speed
#26
Post by 5speed »
just getting into rebuilding my brakes and subscribed to your video's Tom. anim-cheers1
boogie red
#27
Post by boogie red »
Nice video, cool setup, what about this, I just pull a caliper off leave everything hooked up get my spacer setup start pumping!
See what happens, this will be fun, thanks again
76 gl naked, runs good, always tinkering
79 gl all the fairing stuff gone, work-in-progress
68 chevelle hi compression fat block, OH YA! In process of changing gear ratios, I'm excited!
73 tahiti jet 455 olds sweet heart, sad in a way, she gone, traded for a VTX Honda, didn't like it , traded For a Harley 19 Road King Classic, Stage 2, OH YA
tomk1960
#28
Post by tomk1960 »
Smart move! That will do the trick and you saved time by not having to set up on the bench.
1978 Honda GL1000
boogie red
#29
Tom, like I mentioned before there's a cool setup, here's what happened to me, I pop that caliper off and commence the pumping the Piston out this using my brake on the bike it came right out of course you got to separate the caliper to get it all the way out so I'll go over to the other side and I'm like oh hahaha, Hydraulics are open now so I got a Bolt & Nut exact size use the washers put them in that banjo fitting start pumping, well no pressure well that means I had to go back over and bleed it out! pump the other piston out Wawa awesome, they weren't that bad of shape I just polished everything all up, cleaned out those grooves where the seal set everything was just corroded and dirty, even use the same seals, they still had elasticity and I just use some Scotch-Brite and it worked really well I was amazed, feels real good resemble bam I got brakes! bike even runs oh, now I get to do the rear, good stuff life is good, be safe out there in that crazy world right now
oldawg
Rusty Probie
Rusty Probie
#30
Post by oldawg »
Good common sense approach... thank you!
