ONE MODEL: FORD 722F 9510 KAA(VEE FOUR) MANUAL GEARS(single choke)
SPEC:
THROTTLE BARRELL DIAMETER..........1.42in (36mm)
VENTURI DIAMETER............1.11in (28mm)
MAIN JET............0.063in (1.60mm)
IDLE SPEED(rpm).................700-740
FAST IDLE SPEED(rpm).........1700-1900
FLOAT LEVEL..............................1.11in (28.0mm)
FLOAT TRAVEL..................0.276in (7.0mm)
CHOKE PLATE PULL DOWN ......................0.158+-0.02in (4.0+-0.5mm)
DE-CHOKE.................0.315in (8.0mm)
ACCELERATOR PUMP STROKE................0.145+-0.005in (3.68+-0.13mm)
VACUUM PISTON LINK HOLE...........OUTER
THERMOSTATIC SPRING SLOT............CENTRE
FORD 722F 9510 KBA (VEE FOUR) AUTO GEARS(single choke)
THROTTLE BARRELL DIAMETER................1.42in (36mm)
MAIN JET..................0.061in (1.55mm)
IDLE SPEED(rpm)...................700-740
FAST IDLE(rpm)............2100-2300
FLOAT LEVEL.............1.11in (28.0mm)
FLOAT TRAVEL..........0.276in (7.0mm)
CHOKE PLATE PULL DOWN...........0.158+-0.02in (4.0+-5.0mm)
DE-CHOKE..........0.315in (8mm)
ACCELERATOR PUMP STROKE.........0.145+-0.005in (3.68+-0.13mm)
VACUUM PISTON LINK HOLE.........OUTER
THERMOSTATIC SPRING SLOT...................CENTRE
THEY ALSO DID 5 DIFFERENT TYPES(WEBBERS) FOR THE VEE SIX(twin choke)
I CAN SUPPLY YOU WITH SPECS FOR THE CARB IN YOUR PICTURE TRY IF YOU WANT THEM,OR FOR MOST WEBBERS SINGLE / TWIN CHOKE.........
HOPE THIS IS OF SOME HELP............
