A really cheap & easy GL1000 dipstick
- Rusty Probie
last week i was riding my GL1000 1979 and looked in my mirror and saw nothing but white smoke so i pulled off and then seen that there was oil all over the place and it was coming from the top down like around the air box had a buddy show up and we were looking and found that one of the blow bye were not attached to the air box. could that be from to much oil or somthing bad. thanks
Live life to the fullest
You may wish to start with the introduction part of the forum and introduce yourself, then start a new thread to ask your question...
- Rusty Probie
Re:
No nintentoPaxton Gomez wrote:No Comprendo!
- Tin Member
Re: A really cheap & easy GL1000 dipstick
I like to use a dipstick and it is a lot easier than using the site glass. I just got a 79 GL1000 LTD and will try it on the bike. I also have two Yamaha Virgos that also have site glasses and it would be a lot easier if I could manufacturer a dip stick for them also. Thanks for the suggestion.
A new owner from Canada
1974 Honda CB125
1974 Honda CB360
1976 Honda GL1000 LTD
1980 Yamaha SR250
1985 Yamaha XV750
1992 Yamaha XV1100
1974 Honda CB360
1980 Yamaha SR250
1985 Yamaha XV750
1992 Yamaha XV1100
No such thing as a 79 LTD there Pard. The only LTD for the 1000 is the 76.
- Lead Member
How do you open the oil filter without draining some of the oil?
trikeman.
trikeman.
That's filler, not filter. You insert the dipstick through the opening you add oil through.To check the oil I simply park in my usual place, open the oil filler, insert the dipstick, pull it out, and read it.
BTW: I set the dipstick up to measure the level with the bike on the sidestand, which was ideal for a solo bike, but when I added the sidecar that was no longer possible. I have not-so-fond memories of checking the oil on my first 'Wing sidecar outfit many years ago by putting my chest on the seat and hanging my head between the sidecar & bike with a trouble light, a little brush and a screwdriver, trying to read the level before the blood rushed to my head. I knew for sure that I did not want to have do that again so I broke down and bought a dipstick kit.
If you decide to get a dipstick kit, try to get a Drag Specialties one (I found mine on eBay) as shown here. All of the other ones I have seen go into the drain plug and you have to disassemble them to drain the oil. The Drag Specialties kit has it's own drain screw so you can change the oil without disturbing any of the fittings.
I guess I just like crawling around on the ground... I sold or gave away both of the dipsticks I've had to remove.
besides, once I get all the leaks fixed & fill it to the proper level (when changing the oil) by measuring the volume I put in, I don't worry about it. I do watch my ID10T light though... but I glance at all the gauges fairly often. I have a little mantra I recite; charging - good, oil light off - good, fuel level - okay, then look around to dodge the idiots - mmm, fairly well...
H2G2=42
H2G2=42
- Old Fogey
Or as my Old Man calls them, the "Whooops..TOOOOO LATE !" lightsheraldhamster wrote: I do watch my ID10T light though...
- My Album: http://s254.photobucket.com/albums/hh93/head_750/
I just received one yesterday that I bought on E bay, (drag specialties,Has drain hole) But I may have too fiddle with it some as I change always change the Filter with an Oil change as it seems to be a little cramped for space. That is to say just to make it easier to get the Filter housing off and on.Sidecar Bob wrote:That's filler, not filter. You insert the dipstick through the opening you add oil through.To check the oil I simply park in my usual place, open the oil filler, insert the dipstick, pull it out, and read it.
1 1966 CL77 305 Scrambler
1 1967 CL77 305 Scrambler
1 1970 CB750 NO#
1 1970 CB750 Track Bike
1 1972 CB750 High Speed Highway Bike
1 1974 CB750
1 1974 CB550
1 1974 DT360A Yamaha
1 1975 CB750
1 1975 CB750F
1 1975 GL1000 #92
1 1975 GL1000
1 1977 GL1000
3 1981 CB900F
1 1983 CB1100F
And a whole bunch of parts
1 1970 CB750 NO#
1 1974 CB750
1 1974 CB550
1 1975 CB750
1 1975 CB750F
1 1975 GL1000 #92
1 1975 GL1000
1 1977 GL1000
3 1981 CB900F
1 1983 CB1100F
I recently designed, and built a dip stick for the 1000/1100 engines that make checking the oil level a breeze. My motivation was the side car on the 1000. This involves a dip stick that is mounted near the bottom of the frame down tube on the right side, between the frame and the radiator ear. Almost invisible, but all in chrome, and does not interfere with changing oil. Been thinking about it for a while, and by the end of the month they should be for sale on wingovations. I have installed one on Cyborg as well, and it really is nice to be able to stand up and check the oil level, even on the side stand. If anyone is interested in one let me know. the initial manufacturing quantities will be fairly low
ANY PICS? I might be interested! Cost?CYBORG wrote:I recently designed, and built a dip stick for the 1000/1100 engines that make checking the oil level a breeze. My motivation was the side car on the 1000. This involves a dip stick that is mounted near the bottom of the frame down tube on the right side, between the frame and the radiator ear. Almost invisible, but all in chrome, and does not interfere with changing oil. Been thinking about it for a while, and by the end of the month they should be for sale on wingovations. I have installed one on Cyborg as well, and it really is nice to be able to stand up and check the oil level, even on the side stand. If anyone is interested in one let me know. the initial manufacturing quantities will be fairly low
1 1970 CB750 NO#
1 1974 CB750
1 1974 CB550
1 1975 CB750
1 1975 CB750F
1 1975 GL1000 #92
1 1975 GL1000
1 1977 GL1000
3 1981 CB900F
1 1983 CB1100F
1 1970 CB750 NO#
1 1974 CB750
1 1974 CB550
1 1975 CB750
1 1975 CB750F
1 1975 GL1000 #92
1 1975 GL1000
1 1977 GL1000
3 1981 CB900F
1 1983 CB1100F
- NCScooter
- My Album: http://ngwclub.com/gallery3/index.php/w ... ter?page=1
I too might be interested if the $ is right. Pics would be good as well. Thanks.
Sidecar Bob-- Do you measure the oil w/ the bike on the side or center stand? I'm thinking it shouldn't matter as long as I'm consistent. And the oil would be easier to reach on the center stand, no? I might use a perpendicular bend in the wire rather than a loop to stop the wire from going in too far once everything is copacetic, boss.
You guys are the greatest. I admit I didn't read that real long ejicashunal post.
I need to remember to keep my expectations tiny so I don't end up so whiny.
1976 CB400f
1977 GL1000-The Breeze
I'm so special, my short bus only has two wheels!
1976 CB400f
