Made a decision
- Graham Cracker
Re: Made a decision
That's some pretty ugly stuff...good testament about the fuel filter though. Do you have access to ethanol free fuel?
Mark
1976 GL 1000 Sulfur Yellow
1977 GL 1000 Pearl White
Re: Made a decision
Ugh. I'm not liking that! I RedCoted the tank in the 1100 I'm working on now. Hopefully I don't have similar issues...
Re: Made a decision
Another Long HOT day in the shop but worth every drop of sweat.
IT LIVES!!!!
IT LIVES!!!!
Re: Made a decision
You've got it close!
- 77Gowing
Re: Made a decision
WF it sounds great and you say you haven't adjusted the valves or timed it?
You really went to town. I did video of my rig today also.
I'm hung up on the Head lamp and the body work is out.
Anyway, great job.
Anyway, great job.
"Less is More" Anonymous
77Gowing
1977 GL1000 "O'le Blue." (sold
2014 Yamaha 950 V Star (sold)
77Gowing
Re: Made a decision
I just stuck the dyna in there and it fired right up. I did loosen it up and watching the vibration of the mirrors I got it to smooth out a bit. I have one of Randakks Timing wheels and will do that before it hits the road. Not sure where I am going to set it though. This is a 77 engine with a 78 carb rack and 78 advancer. So I am going to have to think on that some. The valves I set when I built it but they will need a tweak before I ride it for the first time. They were removed and new seals put in and lapped so they need to seat some. That electric fuel pump worked nice. First cold start I cranked for maybe 5 seconds before she fired. Now it is touch the button.
It was 93 in the shop today and they are calling for 95 tomorrow so I might get out for a few hours but I am not up for another full day. If I get her on the road by the end of the week I will be happy.
Re: Made a decision
Not close by. The nearest station is about 40 miles away. I normally go out there a couple times a year and get like 15 gallons and I use that for all my small engine stuff but it is too far to use in the bike on a regular basis.Graham Cracker wrote:That's some pretty ugly stuff...good testament about the fuel filter though. Do you have access to ethanol free fuel?
Re: Made a decision
Did the valves first thing this morning, then the timing. With 78 Carbs and a 78 Advancer and 77 Cams I decided on 7.5 degrees for the baseline. Basically half way between the early and late profiles. She seems happy so far.
Re: Made a decision
Never thought it would crack there. I'm going to look mine over. I think you'd like the 77 advancer, although you probably drive this one with more loads. C5 with VOES.
Re: Made a decision
Have to put the beer in the side bags I guess ....
Re: Made a decision
Yea swapping out the advancer is an easy thing to do. Once I get her on the road and see how she responds then I will decide if I want to play with it. This is a dressed over the road bike so economy and longevity is really more of a concern than speed performance. IIRC the advance for the 78 was like 5 degrees less at full. I suspect that could have a bigger impact on the cam performance than the carbs but I am just guessing. A little concerned she might run lean and maybe enough to have some knocking. Too many variables for me to figure in my head so I will have to experiment a bit while riding it.
I know when I checked the advance operation today with the strobe it did not quite hit the full mark for the 75 profile timing wheel I used and I had set the baseline at about 7.5 BTDC as opposed to the stock setting of 5 for that engine.
Re: Made a decision
RAT wrote:Have to put the beer in the side bags I guess ....
Back seat
The more I look at this and think about it those cracks show up where you would expect for a bike that is overloaded. The shocks would push those tail piece extensions up but the weight of the top box I think would push them down?? I carry a lot of stuff but I did not think it was that much. 99% of the time I ride solo and even when she is aboard the Better Half is not a big girl.
I know for the rest of the year my tools will be in the side boxes or in the seat behind me.
Re: Made a decision
Unfortunately the temp does not show the heat index of the humidity NW OK is very humid and so the temp may be 100, but the humidity makes it feel like 110 (when the sweat is rolling down the end of your cap a 10 am)
sort of like the humidity in San Francisco, makes the summer 55 feel like the low 40's (the coldest winter I ever spent was a summer in San Francisco)
back to the thread.... that is some pile of er, stuff, n the tank. Gotta love that humidity in Norfolk
Re: Made a decision
Well she rides! First ten miles down. Had to jump inside to check the radar. Can hear boomers starting up but it looks like I can sneak out for a bit.
- Old Fogey
Re: Made a decision
Yay!
Boomer? another Americanism? thunder maybe?
