Pics at last!
Old Fogey
Post by Old Fogey »
I found some great stuff for doing 'things' with that don't have anything else to do them with, if you see what I mean.
Electricians use this. Its a rubbery tape that is not sticky but bonds to itself;
self-amalgamating or self fusing tape.
The state my rear brake linkage was in when I got the old heap had to be seen to be believed, so I wanted to make sure that didn't happen again.
It looks like tape but when pressed hard together it becomes one piece. Its some sort of rubber material and stretchy.
The brake pedal has had the pivot hole each side chamfered and a thin rubber 'O' ring inserted to seal out any water. The assembly can be quite tight to keep out the muck as long as its lubed properly because the big spring has more than enough pressure to return the pedal.
All connection had some corrosion , some more than others as well as broken connectors, bare wires etc. after doing all that work to put the harness right I thought this might help keep it that way.
Thats not rust you see, by the way; it's copper based grease.
RIP: 1950-2011
Post by Cookie »
I know you guys have a lot of corrosion issues since I used to work on London Taxis and owned one corroded one myself. Anything you can do to reduce it may help. Hampster and I were both surprised by the amount of corrosion in our rear masters and I live in CA.
Alley Kat
Post by Alley Kat »
Hey John, good stuff, piccies at long last! Gauges look superb mate, as does the rest. Need more pics!
Old Fogey
Post by Old Fogey »
These were taken before I move it down to the garage.
Down?
Yup! I was building this in a first floor flat in my spare room!
You all guessed. Yeah, I live on my own :lol:
This was just at the start of assembly. You can just see one bit of the sealed up frame.
As much as I could do before shifting it down, due to the weight.
Upstairs workshop!:shock:
RIP: 1950-2011
Post by Cookie »
Let's see now, the first floor is the second floor over there?
Old Fogey
Post by Old Fogey »
You got it right!
That's looking brilliant. Glad you got the camera/pc sorted out. Those are some inspiring shots.
Keep up the good work!
RIP: 1950-2011
Post by Cookie »
OK, let's get this straight. you are going to have it on the ground floor when you put the heavy stuff in and not be like those guys that build cabin cruisers in their basements right?
Old Fogey
Post by Old Fogey »
The pics with the blue wallpaper were taken in the spare room of the flat which is one floor up.
The ones in the wooden building are in my garage next to the flat.
I actually videoed myself going up stairs and into the room with the bike because folk didn't believe me but at 33Mb its too big to post amd I don't know how to reduce the size of it.
No basement! :-D
Lobo29
Brass Member
Brass Member
Post by Lobo29 »
Nice work.
:-D
Have a good day!
Lobo29
silver b
Post by silver b »
I look foreward to see this bike coming togheter, looks verry "hiclass" !
Member of Fauske MC
Honda gl 1000 Bobba 76
Honda cx 500 cafè 78
MY ENGLISH IS BÆD !
My galery http://www.nakedgoldwings.com/gallery/silverb
Old Fogey
Post by Old Fogey »
Cookery lesson :twisted:
(Mouse-over on pics)
<table><tr><td><embed></td></tr><tr><td><img></td><td><a><img></a></td></tr><tr><td><a>Take one of these....</a>, <a>Add one of those.. mix thoroughly....</a></td></tr></table>
<table><tr><td><embed></td></tr><tr><td><img></td><td><a><img></a></td></tr><tr><td><a>...to get one of these !</a></td></tr></table>
OK that didn't work too well, did it!
Old Fogey
Post by Old Fogey »
Try again!
no mouse over this time.
Take one of these...................................add one of those.......mix thoroughly.............
...and get one of these! dancr
Old Fogey wrote:Cookery lesson :twisted:
:lol: :lol: :lol: :lol: No not so well :lol: :lol: :lol:
timma11
#30
Post by timma11 »
Old Fogey, thank you for getting a camera/pc combo that works! LOL! you ARE doing nice work, just as i suspected. and it is nice to see it. keep 'em coming!
timma11
"studies have found that people with schizophrenia are about twice as likely to smoke pot as those who are unaffected"
