OIL CONTAMINATED
Re: OIL CONTAMINATED
Ya, found several on e-bay. But they are designed for cars, of course, so mounting and the length of tubes etc. have to be a concern
CHUCK HAHN
Thread size and pitch could be an issue too. All a guy can do is try one and do a return if its not doable.
My bikes::
1973 Yamaha TX 750
1975 Honda GL1000 Goldwing
1976 Kawasaki KZ 650B1
1978 Suzuki GS 1000C ( 1 )
1978 Suzuki GS 1000E (2)
1979 Suzuki GS 1000S
1999 Valkyrie
1986 Ninja 600R
1973 Yamaha TX 750
1999 Valkyrie
1986 Ninja 600R
That does happen. But I have the tools to make most anything fit most anything
redglbx
Cyborg, can’t seem to find the extra kit I bought for mine but the numbers on the one on the bike sent me to Amazon and p/n RAF-9+SW-Kit,,it’s all about $25 there.. That said mine is a straight blade unit so a curved blade unit (also available ) may run a bit quieter.. A 10” unit could probably be fitted as well.
Thanks for taking the trouble. I'll check into it
CHUCK HAHN
Update on the advancer. the ends of the springs were stretched a lot and the weights had a lot of free play. I tweaked the loops till the slop was gone and redid the timing. It sat on the lift well over 15 minutes and the tach was rock steady with not one episode of run away RPMs.
Then i screwed the pooch. I went to get new screws as the ones that were on it were rather chewed up. I undid a screw from the subplate not realizing i had taken the other one with me to get the new ones.. yup the plate moved out of position. I just replaced the other ones and came home pretty disgusted with myself. So now i gotta redo timing for the umpteenth time. BUT i know the hanging idle and runaway RPMs are gone. Small victory. Followed by a small defeat.
My bikes::
1973 Yamaha TX 750
1999 Valkyrie
1986 Ninja 600R
1973 Yamaha TX 750
1999 Valkyrie
1986 Ninja 600R
redglbx
Chuck,, we’ve all been there
,,, but you got it now !
CHUCK HAHN
Has been a long trip and some good practical learning for sure. I hope tomorrows the last time with it.
My bikes::
1973 Yamaha TX 750
1999 Valkyrie
1986 Ninja 600R
1973 Yamaha TX 750
1999 Valkyrie
1986 Ninja 600R
redglbx
CHUCK HAHN
Been checking shop talk and gurus corner but cant find anything specifically about how to test the condenser.
What the setting on my multimeter to use and whats the procedures? Im assuming you do the test on both leads from the condenser??
My bikes::
1973 Yamaha TX 750
1999 Valkyrie
1986 Ninja 600R
1973 Yamaha TX 750
1999 Valkyrie
1986 Ninja 600R
