Off-Idle Stumble - Causes?
WingMan71
Post by WingMan71 »
Troubleshooting an off-idle stumble on my '76 GL1000 LTD problem. (Now owned by a friend of mine.)
After about 1,000 miles of riding it has developed an off-idle stumble upon cracking the throttle open fairly quickly, not when opening the throttle just gradually.
Carbs were removed by me, completely disassembled, sonically cleaned, and re-assembled with a Randakk's Cycle Shakk carb kit about a year before I sold it. I know what I'm doing and have rebuilt dozens of carbs on vintage bikes. So, they were done right. Pilot screws set to 3 turns out, as recommended by Mike Nixon's book. Carbs properly synchronized. Bike was running great when I sold it.
My buddy says he keeps Stabil in the (ethanol) gas, but the bike gets ridden only weekly. So, there's that issue. I'm thinking partially plugged idle jets.
Would appreciate any other ideas regarding the off-idle stumble.
2006 Gold Wing GL1800 CSC Trike
1976 Gold Wing GL1000 LTD - SOLD :(
1987 Gold Wing GL1200A Aspencade - SOLD :(
1982 CB750 Custom - SOLD :(
U.S. Navy SWO 1967-1976
redglbx
Re: Off-Idle Stumble - Causes?
Post by redglbx »
Replace the low speed #115 air jets in the brass elbows with #110’s that should fix it.. some go with #105 or 107’s but I’ve had good luck with the #110’s . This is a noted problem with the early wings but doesn’t affect them all. Easy to do on the bike. I get mine from PJ Motorsports.
WingMan71
Post by WingMan71 »
Thanks much for that tip and the source for the jets.
OhioBill
My Album: http://www.ngwclub.com/gallery/v/wingmans/OhioBill
Post by OhioBill »
Check the resistance of spark plug caps. I chased the same problem with carb overhaul, off and on multiple times. Turned out to be spark plug cap.
OhioBill
Retired and Loving it.
1979 Black (to be restored)
1979 Blue (Sold)
1993 blue 1500 Sold
1976 Restoring
How many years ago did you last time have these carburetors apart ? 🤔
Leave jet sizes be and go through the entire system, again.
Drain the stabilized gasoline and start the engine afterwards with new fresh gasoline.
Actually, simply a new fill of non-treated gasoline into the system might be the best way to approach the "mystery" ?
redglbx
Post by redglbx »
Ohio Bills spark plug cap suggestion is a good one,,, measuring across just the caps should read less than 5k ohms.
WingMan71
Post by WingMan71 »
OhioBill wrote: Sun Aug 24, 2025 5:30 pm Check the resistance of spark plug caps. I chased the same problem with carb overhaul, off and on multiple times. Turned out to be spark plug cap.
We'll do that.
Thanks for the suggestion!
Check the header temps at idle and make sure it is firing on all 4. Also do the idle drop out. Easy checks. Most times I have found a stumble is due to it not hitting on all 4.
WingMan71
Post by WingMan71 »
Whiskerfish wrote: Mon Aug 25, 2025 4:26 pm Check the header temps at idle and make sure it is firing on all 4. Also do the idle drop out. Easy checks. Most times I have found a stumble is due to it not hitting on all 4.
Thanks. We'll check that.
