intermittent starter the starter/headlight switch is fading
Don R
The 1978 20 year sleeper has begun to crank intermittently when starting. It will cut-out, and then if I let off the button and push again it will crank and start. It's not ignition, just the starter motor cutting out. I'm thinking maybe the brushes are worn. I had a GL starter rebuilt once but it was my 79 and that shop recently closed.
I remember removing the exhaust pipe and the rear stud on the 79, I'll do a search on starter removal. It's got 61,000 miles now. Ideas? I do have a set of 750 brushes in stock, no idea if they might work or not.
Re: intermittent starter
If the battery is strong, I would guess brushes. Brushes are cheap and easy to change. If that low mileage, probably just needs brushes and a cleaning
redglbx
Might also be the start button itself,, probably the brushes but the starter button is also suspect. Does your headlight always come back on when you release the button ?
Don R
I watched it this morning, it wasn't cranking at all and the headlight operated properly, I tapped the starter with a plastic mallet and it started several times in a row. I'll still load test the battery, but it does look like brushes.
Thanks for the feedback.
redglbx
Good luck Don ! Sounds like you have it figured out.
Don R
It turned out to be the start button, if I push it in a little it starts fine, if I push it in all the way it stops cranking, now where to get a replacement?
Don R
I'm not finding an oem right control replacement anywhere, are there some generic replacements like K&S that are good enough quality? How about oem from newer goldwings? I don't have a problem figuring out wiring, its a fun challenge.
redglbx
Re: intermittent starter the starter/headlight switch is fading
Don, there are several new ones on eBay currently, also could check David Silver and CMSNL . These are common across several models and I will add that now’s a good time to put the headlight on relays so you take that load off of the button contacts.
Don R
I'll check ebay again, DSS and CMSNL don't have any. The one I saw on ebay was $325. I'm not ready to do that.
I bought a Toyota land rover retrofit headlight kit shipped for $40, it has two Koito 7" H4 headlights, relays, fuses and a wiring harness that can be taken apart and used on whatever. It's part 81110-60P70. They have been tested on bikes on the SOHC4 forum and have a good light pattern, the bulbs do protrude a little forward of the chrome ring. They came from Toyota parts overstock.
I plan to use one the bulbs, a relay and a fuse to re-wire the headlight once I get a reliable switch. I've already got the ignition power on a relay.
I must be searching incorrectly, the only right controls I find are Rygo replacements for 75 and 76 gl's, used ones and the one $325 new one that shows sold. I searched for start stop switch, right control and the part number for 78, 79 and 77.
I have no doubt that I can wire one made for a 76 and make it work China made might even get expensive in the near future.
redglbx
Don, I found several on eBay that are new and sub $50,,
Don R
I'll probably go with the ebay rygo brand replacement, it's $37 delivered to my door. I was hoping to find NOS but at the price I'll switch it to aftermarket. I'm guessing the $60 Forsetti brand control is the same switch as the $37 Rygo with a different name stuck on it.
I don't see much sense going with old used parts since they are likely to suffer the same failure soon. Thanks for the replies.
- NotSoLilCrippseys
Suggestion: Get some electrical parts cleaner spray and clean the controls (left and right).
Getting the dust/gunk out might improve the action on your start button. If it works sometimes, it seems like improving the connection would help it work all the time.
You're out maybe $5 and have plenty left for the next 50 times you want to clean an electrical connection.
If it doesn't work, then go with something new (or a used part from one of the many bike breakers selling on eBay).
In the Stable and Ridable
1978 CB550K - son's cafe
Sold
Sold
Don R
The contact cleaner is easy enough to try, I even have a can. I've seen this on 75 and up 750's with no headlight switch, it's almost always caused by the plastic cage that holds the contacts getting brittle and crumbling.
Contact cleaner should always be the first thing you try when a switch is giving you trouble.
And if you end up needing a part and you can't find one locally contact this guy
https://vintagemotoswitcheroo.au/
